2006 AC charge
Old 02 Jul 2013, 06:14 pm
Default 2006 AC charge
How much R134a is in the ac system? The FSM says "NOTE: Please refer to the underhood HVAC Specification sticker for the latest refrigerant fill levels for
the vehicle being worked on." Where's the sticker?!
2006 PT Cruiser (Wife's)
2007 PT Cruiser (Son's)
2001 Ram 2500 Cummins (Mine)
Old 02 Jul 2013, 06:45 pm
randyincctx's Avatar
Exclamation Re: 2006 AC charge
Total Refrigerant Capacity R134a = 1.125 lbs.(2006 NA)
SOURCE: A/C system capacity
Aka:~KILLER~
Old 02 Jul 2013, 09:06 pm
Default Re: 2006 AC charge
My search skills need some improvement.
Old 02 Jul 2013, 10:21 pm
Talking Re: 2006 AC charge
Don't feel bad....Search function on here is a little 'wonky' sometimes.(That's why I use Google,and it normally leads me back here!lol)
Aka:~KILLER~
Old 03 Jul 2013, 11:14 pm
Not sure what Randy's point was - on the '06 PT GT, it's a 510 gram system. However, you cannot base the charge on the weight of the R134a - you have to pay attention to the Pressure::Temperature graph and measure the pressure on the Low side, so that when you charge your system, you put the right amount of R134a in it!
Here's a link on mine, I just posted this a few weeks ago: HOW TO VACUUM DOWN & CHARGE YOUR A/C SYSTEM
Now I don't mean to slander Randy, but the "poundage" of R134a is totally incorrect. If you load up more than the factory sticker under your hood states, then you are putting way too much pressure on your system. Add to it, if you really want your system to work better than factory, and if you've never opened any of the lines, then find a place that can suck down your existing R134a (get it all removed), then vacuum down your system for a minimum of 1 hour, then recharge your system with new R134a, including about 1 ounce of PAG46 oil.
I'm telling you the truth - facts - I've tested my system so many times and went in so many incorrect directions based on what info I got off these forums that I finally figured out (oh yes, after spending an entire day with a Senior Mechanic at Chrysler) how to make my system work fabulously. You're more than welcome to come sit in my PT and freeze your butt off!!
HOW TO VACUUM DOWN & CHARGE YOUR A/C SYSTEM Chromenut Tech & Performance Forum 9 27 Jul 2016 02:05 pm
Turbo Charge? dzyubin Tech & Performance Forum 12 06 Oct 2011 09:57 pm
A/C Re-Charge price? edj8 General PT Cruiser Discussions 6 26 Jun 2010 09:34 pm
Turbo charge upgrade Help demon666 Tech & Performance Forum 3 14 Jul 2009 08:14 pm
srt-4 Upper Charge Pipe BradentonBreeze General Turbo Discussions 6 16 May 2009 08:10 pm
