PT fan motor assembly problem
Old 03 Jul 2013, 11:06 am
Default PT fan motor assembly problem
I own a 2007 PT.
It was involved in a minor front in fender bender. I made the minor repairs required to get the car back on the road.
I had to replace the fan housing due to damage to the unit.
All was fine for several months then the fan assembly went out and I replaced it thinking it was a defective unit. Within the next couple months I have replaced the motor assembly 2 more times still thinking they were just bad units. It has gone out again.
Now I am thinking it must be something I have missed in the diagnostics of the motor assembly or maybe deeper.
Anyone had this problem with their PT? Does anyone have any thought what I should look at to fix this problem?
Old 03 Jul 2013, 10:36 pm
Default Re: PT fan motor assembly problem
Originally Posted by ranchand View Post
I own a 2007 PT.
Have you checked to see if your holding any error codes?
Old 03 Jul 2013, 10:38 pm
Did you replace the assembly with a used motor or new? If you used a used motor with the assembly the motor couldbe running slow when on high speed cooling. Also does the blade spin freely, any binding could causing it to burn out. One other thing did you get the right blower for the right car? The turbo models carry a different speed control than that of the regular aspirated engine.
Hope this helps.................
Old 05 Jul 2013, 11:26 am
yes I have checked for error codes. There are none
Old 05 Jul 2013, 11:31 am
the replacement unit could have been a remanufactured unit. That is why I thought it was a defective unit. But after the third unit went out I am thinking it must be something else. Yes I made sure it was the right unit for my car. There has to be something I'm missing that is causing these units to quit.
Old 05 Jul 2013, 08:17 pm
Correct me if I'm wrong, but since it's 2nd gen does the comp not control the fan to a certain extent? Could it be sending surges shortening the life of the fan and could it not be bypassed with a separate fan control kit?
02' Touring
[HELP!] Problem with jacking up the motor SVAFnemesis Tech & Performance Forum 6 28 Aug 2012 08:37 pm
Fan Assembly bnicolet General PT Cruiser Discussions 1 27 Feb 2011 05:01 pm
Sunroof assembly Freezinghot Exterior Accessories Forum 8 14 Jan 2011 11:02 am
What if the Watts assembly goes bad? edb PT Cruiser Convertible Forum 5 18 Oct 2010 08:02 pm
Problem with my turbo, fan, spark plugs, or motor? TheFox Tech & Performance Forum 7 28 Aug 2008 10:52 pm
