help!!! code PO 0116 problem?
Old 04 Jul 2013, 07:19 pm
Default help!!! code PO 0116 problem?
need help quick!! My 05 cruiser touring N/A automatic idles and runs and drives perfectly normal, with one exception. When accelerating heavily as if to pass another vechile the enigne immediately stalls. to resume normal driving simply ease up on the gas petal and all is good again. the only other problem is the cruise control will turn on but the cruise light goes out about 5 seconds later and will not turn back on. car shows only one error code PO 0116 (crank cam corr. error). crank and cam sensors including cam sensor target replaced with mopar parts, new platnium plugs and plug wires as well. cat convertor removed , checked and not restricted, at idle in netural under heavy acceration engine stalls above changes have produced no results can anyone help with this nightmare? Quicksilver
Old 04 Jul 2013, 07:30 pm
randyincctx's Avatar
Lightbulb Re: help!!! code PO 0116 problem?
Code P0116 in your PT Cruiser indicates a problem in the coolant temperature sensor circuit that is causing the coolant temperature to be inaccurate.........2......Read more: How to Fix a P0116 PT Cruiser | eHow
Aka:~KILLER~
Old 07 Jul 2013, 09:07 pm
Default Re: help!!! code PO 0116 problem?
My bad you guys sorry about that i qouted the wrong code in above post the real code P0016 "cam/crankshaft pos. correlation sensor A bank 1" can any one advice
Quicksilver
Old 16 Feb 2014, 11:15 am
Replace your MAP Sensor. MAP Sensors are the hardest to diagnose, because the computer thinks they are working just because they are sending a signal. The computer has no way to determine if the signal is correct or not, for some reason. Easiest and probably the cheapest fix of all. Requires a Torx 15 driver. $18 at Autozone with a LLT Warranty.
Old 17 Feb 2014, 05:41 am
Quic; I'd start by wiggling and inspecting wires from the cam sensor to the computer. A bad cps or cps magnet might cause the code. Or a skipped tooth on the timing belt?
Old 17 Feb 2014, 07:45 am
Don, I'm with the above. Even though the Cam/Crank sensors are new, check the electrical connections and the wiring harness for any signs of wear. Might have to get to a scanner for further diagnostics. First, try the old and true method of taking off the negative battery cable for 5 minutes to reset the computer. Step on the brake pedal while it's unhooked and put it all back together. Can't hurt.
Problem with Code P0481 214DallasTexas General PT Cruiser Discussions 10 03 Nov 2017 03:08 pm
2003 oil sensor problem code 522 jbander Tech & Performance Forum 2 27 Mar 2013 05:15 am
P1684 code and dONE problem jimgas Tech & Performance Forum 9 17 Sep 2012 09:55 pm
Error Code- Can't find problem classiccruiser Tech & Performance Forum 2 02 Apr 2012 08:25 pm
