rear end noises
Old 05 Jul 2013, 07:26 pm
Default rear end noises
I bought my 16yr daughter a 01 cruiser. Has a rattle noise in the rear end. we replaced the shocks, the were toasted, replaced the watts bell crank, center bushing was shot, and also replaced the upper and lower watts links. put a zip tie around the fuel filler hose case that was smacking the plastic rear wheel fender, spare tire is tight and still a noise. just had three people in the back and noise went away. any suggestions really stumping me!
Old 05 Jul 2013, 07:35 pm
Default Re: rear end noises
is there a rear swaybar?
just a thought, check the exhaust for bad holders.
2016 Kia Soul Plus Black
Old 06 Jul 2013, 04:35 pm
May sound a bit odd, but have you made sure the spare tire rack in the back under carriage is secured. the jack in the side panels should be checked to.
Old 07 Jul 2013, 10:03 am
Spar tire rack seems tight. Found that the driver sideswsy bar link was bad changed both sides out this morn and 90% of the noise is gone. Would have changed the sway bar clamp bushings but no parts store around by my had them in stock will have to order those next but the bulk of the noises are gone!
bushings...and weird noises... superpug666 Turbo Wheels/Suspension/Handling 1 04 Sep 2010 04:43 am
Cabin ventilation noises? DIYPTGUY Tech & Performance Forum 3 05 Nov 2009 06:52 pm
Front end noises when turning, FloridaCrusier29 General PT Cruiser Discussions 10 06 Apr 2009 09:57 pm
unusual brake noises 4SPEED General Turbo Discussions 7 21 Feb 2009 11:42 am
Turbo noises quicksilverdon General PT Cruiser Discussions 5 05 Apr 2005 02:08 pm
