▀█► PT Cruiser AC Big Problem
Old 06 Jul 2013, 03:25 am
Default ▀█► PT Cruiser AC Big Problem
2006 PT Cruiser Touring Edition AC Problem, System was evacuated properly. As I begin to refill almost at the end of the 1st can. The low pressure side jumps from 40 to 110 and the compressor start working hard. This is the second time I evacuated the system with same results.
This is with one can only after system evacuated.
Low Side High over 110
Car Compressor acts like I put to much
Compressor kicks in Shakes car.. Low side drops from
110 to 90 then back to 110 continues same..
Don't what else to do..
Old 06 Jul 2013, 02:40 pm
Default Re: ▀█► PT Cruiser AC Big Problem
It takes roughly 1 1/2 cans to fill system, right around 540 grams. Try putting in proper amount and see, also it may need some pag oil.
02' Touring
Old 06 Jul 2013, 09:54 pm
Do you know the location of the Expansion valve?
2006 pt cruiser Touring edition..
I can't find it anywhere
Old 06 Jul 2013, 10:40 pm
I think the expansion valve in this case is called an "orfice tube" and is a non serviced item and contained in the liquid refrigerant line from the condenser to the evaporator unit. A partiially plugged or defective one will cause the "high-low pressure side / high-high pressure side" readings you describe in your post.
Old 06 Jul 2013, 10:48 pm
orfice tube?
Wouldn't it be obvious looking at the tube that it had it?
I don't see one in this year model..
Old 07 Jul 2013, 01:41 am
cruserdad1976's Avatar
I don't thinkg the pt has a orfice tube
Old 07 Jul 2013, 03:57 pm
http://shop.advanceautoparts
2006 Chrysler PT Cruiser Touring
Can Use 56832; Includes Orifice Tube; CAN BE TOUGHONE OR FACTORY AIR PRODUCT DUE TO RUNNING CHANGE
Liquid Line Hose Assembly w/ Orifice Tube; Can Use 56832; CAN BE TOUGHONE OR FACTORY AIR PRODUCT DUE TO RUNNING CHANGE
Old 07 Jul 2013, 04:00 pm
My gauges indicate 45 on liquid line . That liquid line gets really hot . Is that ok?
I only used 1 can..
Add 134a on the PT is diff from other cars..
So much stress!
Old 07 Jul 2013, 04:04 pm
Outside temperature is now 90..
What should be my High side reading?
350 ? 400?
Old 07 Jul 2013, 04:50 pm
I replaced the Liquid line w/Orfice new and new accumulator. Vacuumed the line for 45 min. Waited 30 after.. No leak..
I filled 1 can and 1/2
The Liquid line gets hot and High gauge displays 410
06 Cruiser cooling fan problem Jimmyo Tech & Performance Forum 13 21 May 2014 10:26 am
01 Pt cruiser problem bmdakk General PT Cruiser Discussions 2 06 May 2013 10:41 am
02 pt cruiser problem starting nemesysr Tech & Performance Forum 6 03 Feb 2013 09:19 pm
Problem with my Mom's PT Cruiser GT silverwolf22 General PT Cruiser Discussions 5 14 Nov 2010 02:48 am
04 Cruiser AC problem (I think) mscaho Tech & Performance Forum 9 20 Aug 2007 12:58 pm
