▀█► A/C expansion valve location? 2006 PT Cruiser Touring Edition
Old 06 Jul 2013, 09:40 pm
Default ▀█► A/C expansion valve location? 2006 PT Cruiser Touring Edition
Hi
Can anyone help me?
No picture Diagrams anywhere found on Google.
Can someone post a diagram location..
Old 06 Jul 2013, 10:32 pm
Default Re: ▀█► A/C expansion valve location? 2006 PT Cruiser Touring Edition
I think the expansion valve in this case is called an "orfice tube" and is a non serviced item and contained in the liquid refrigerant line from the condenser and the evaporator unit. A partiially plugged or defective one will cause the "high-low pressure side / high-high pressure side" readings you describe in your other post.
Old 07 Jul 2013, 03:55 pm
Yes your right!
ToughOne or Factory Air Hose Assembly
Part No. T56832
A/C System Manufacturer: Chrysler
Material: Aluminum; Rubber
O.E.M. Number: 5058272AD
O.E.M. Replacement: Yes
2006 Chrysler PT Cruiser Touring
Can Use 56832; Includes Orifice Tube; CAN BE TOUGHONE OR FACTORY AIR PRODUCT DUE TO RUNNING CHANGE
Liquid Line Hose Assembly w/ Orifice Tube; Can Use 56832; CAN BE TOUGHONE OR FACTORY AIR PRODUCT DUE TO RUNNING CHANGE
I found at
advanceautoparts
▀█► PT Cruiser AC Big Problem ken2028 Tech & Performance Forum 11 07 Jul 2013 09:46 pm
PT Cruiser 2002 AC Expansion Valve? larcoelho Tech & Performance Forum 1 23 Aug 2012 05:05 pm
A/C expansion valve location? pppt03turbo Tech & Performance Forum 8 10 Aug 2011 12:37 am
2006 PT Cruiser Touring Edition Reynolds1961 Tech & Performance Forum 3 04 Oct 2010 09:31 pm
2006 PT Cruiser Touring Edition zharrison07 General PT Cruiser Discussions 15 16 Feb 2010 10:16 am
