Squealing belt, dimming lights at odd times
Like Tree2Likes
  • 2 Post By CREWZIN
Old 10 Jul 2013, 06:03 pm
Default Squealing belt, dimming lights at odd times
I have a 03 2.4l 5 speed. I have a terrible belt squeal at start up. If I rev the engine a few times it will stop. But it comes back if I sit at idle for a minute or two, like at a drive thru or traffic light. I've also noticed when it squeals my lights will dim a little. It's more annoying than anything but I'm concerned I may have an alternator problem coming. Any advice would be appreciated. Thanks
Old 10 Jul 2013, 06:48 pm
Default Re: Squealing belt, dimming lights at odd times
Sounds like your alternator belt has stretched or the alternator itself has moved allowing the belt to become loose. If the pulley on the alternator is turning and the belt is that loose, it's not charging the battery like it should.
You can take the passenger front wheel off including the inner liner and try and tighten the belt (or check it to see what kind of condition it's in) or have the dealer/mechanic do it.
Carl48 and UptownSport like this.
Old 10 Jul 2013, 07:06 pm
My pt does the same exact thing and I have found that it may be the tensioner pulley (I think not sure not really mechanically apt I'm more into audio than anything) but I just installed a Mechman 240 amp HO alternator and replaced the belt and it's as tight as possible and mine still has the same symptoms as yours. It did it with the stock alt and belt too leaving me to believe that it is the tensioner pulley. I've watched it while it made that horrible noise before and it was the big pulley thats just behind the heat shielding. My Mechanic says that after awhile this has to be replaced. Hope this helps some and also check your belt as Crewzin already stated and make sure it is tightened up all the way. That belt should be so tight around the alternator that it should feel like steel almost. Hope you get your problem fixed! I know just how annoying/embarassing it is!
The LedGlow Cruiser]
[COLOR="Black"]-Soundstream vir 8300-NR touchsreen headunit
-6 skar vvx 12's (dual 4 ohm)
-12 cubic foot box tuned @ 32 hertz
-re audio mids and highs
-Dc audio 3.5k
-Mechman 240 amp alt
-Cadence 0 gauge all around
-Plasti dipped rims and bumpers
-"Blue" VVME HId low, 15k high beams.
-149 db @ 38 hertz (need to get re metered)
Old 11 Jul 2013, 11:08 am
UptownSport's Avatar
It's OK if it squeals, I purposely like it loose so alternator bearing doesn't fail due to excessive tension
Sounds like your's is a little too loose, tho!
I don't believe the alternator belt has a tensioner pulley ... Am I wrong here?
Old 11 Jul 2013, 11:37 am
Not wrong. Tightening of the alternator belt is done with adjustment of the alternator itself by means of the pivot and adjustment bolts. No tensioner pulley except for the timing belt.
Old 11 Jul 2013, 06:10 pm
...and serpentine drive belt for p/s pump and a/c compressor.
Old 11 Jul 2013, 06:44 pm
....and that one too.
Need help with Squealing belt. superjew78 General PT Cruiser Discussions 10 02 Nov 2012 09:56 pm
2005 pt cruiser turbo belt squealing bvaters General Turbo Discussions 2 21 Oct 2012 12:22 am
Belt squealing bhunt41 Tech & Performance Forum 4 03 Nov 2011 07:32 pm
New Drive Belt Still Squealing - Now What? falconut Tech & Performance Forum 5 25 Mar 2009 04:18 pm
DIMMING LIGHTS AND PCM'S 1SPRINKLERMAN General PT Cruiser Discussions 9 26 Jan 2004 10:04 pm
