NO BUS
Old 11 Jul 2013, 08:14 pm
Default NO BUS
Hello. I have a 2006 PT base model. about 2 months ago we went through the auto car wash and the car turned off in the middle of it. and the dash says NO BUS. The car will not start, but it thinks its on if that makes since. Without the key, you can roll the windows up and down, and unlock, but not lock the doors. and as soon as you hook up the battery, all of the lights come on. With the key turned on, you can use the air conditioner. The radio doesnt work at all. We replaced the PCM. (the mechanic said he scanned it and that's what it said, but after that didn't work, he said he didn't scan it.) I had my brother come out and use the scanner (the one they use at advance) but it wont connect to it. All of the fuses were tested and are good. Im really hoping that it can be something that we can fix at home instead of sending it somewhere to charge $500 or more for a 50 part or something. I really would like my car back.. does anyone have any ideas?
Old 11 Jul 2013, 08:46 pm
randyincctx's Avatar
Lightbulb Re: NO BUS
I take it this car wash was the kind that sprays from underneath also........Have you checked to see if water may have gotten to the PDC?(Maybe the cover wasn't on tight enough).....I also recomend taking a look at this thread:No Bus
Aka:~KILLER~
Old 11 Jul 2013, 08:50 pm
Default Re: NO BUS
Thanks. I tried searching, but it wasn't working.
Old 11 Jul 2013, 09:38 pm
Thumbs up Re: NO BUS
I try searching here first,and if I'm not finding what I'm looking for......I try Google and it normally leads me back here!lol
zamfir2 likes this.
Aka:~KILLER~
Old 11 Jul 2013, 09:42 pm
Default Re: NO BUS
Dang canbus system
Old 12 Jul 2013, 07:32 am
Default Re: NO BUS
Try these.....
no start won`t turn over says NO BUS
http://www.justanswer.com/chrysler/5...r-cut-off.html
Old 12 Jul 2013, 08:02 am
Default Re: NO BUS
When the "NO BUS" was displayed on my son's Jeep Cherokee, it turned out to be a defective crank position sensor which we replaced and solved the problem. However, the only symptoms were no start and no instruments...it did not have all the other symptoms you describe. It does not have a TIPM like that found in your more complex PT electrical system.
Since your problem happened at the car wash, water is a likely culprit. Problem is finding what it got into...just about any 5 volt sensor or data bus connector that got wet could bring down the bus. Hopefully it's not the TIPM.
Old 12 Jul 2013, 08:44 am
Ray_Dockrey's Avatar
Default Re: NO BUS
Have you tried unhooking the battery for about ten minutes? Press the brake pedal a few times while it is unhooked to rid of any residual power. This will reset both the PCM and the TIPM.
Old 12 Jul 2013, 07:51 pm
Default Re: NO BUS
Thanks guys. I am going to try and check some stuff out this weekend. This is what the interior lights do when turning the key...
Old 12 Jul 2013, 07:53 pm
Default Re: NO BUS
Dash lights, sorry.
