won't start
Old 14 Jul 2013, 12:34 pm
Default won't start
was driving,the engine shut off and now it turns over but won't start.checked for fire,engine is firing and the timing belt looks good.when it turns over it almost sounds like there is a drag to it.checked for codes and there are none.i'm at a loss.
Old 14 Jul 2013, 12:36 pm
Default Re: won't start
Is the timing belt moving when the engine turns over? It may have broken. You can remove the upper timing belt cover, or remove the cam position sensor and see if the magnet underneath turns when you crank the engine.
Old 14 Jul 2013, 12:38 pm
yea,i have it pulled down to where i can see the whole belt.everything is moving like it should
Old 14 Jul 2013, 01:28 pm
randyincctx's Avatar
Lightbulb Re: won't start
Check the Camshaft Position Sensor wiring from end to end...See if it is melted,or cracked along the way,be sure to check it ALL the way back!(Sensor to Plug-in)
Aka:~KILLER~
Old 14 Jul 2013, 01:34 pm
will do
Old 16 Jul 2013, 01:29 pm
ok,i have checked and i'm getting gas and have a strong spark,also checked and have compression,retimed belt and no codes are popping up.what am i missing?
Old 16 Jul 2013, 06:42 pm
Exclamation Re: won't start
You'll need to post more info about your PT Cruiser........That way some of the other members can have a chance at helping solve your issue......Give as much info as possible,it will definately help.
Aka:~KILLER~
Old 16 Jul 2013, 10:02 pm
it's a 2002 pt.was driving,the engine shut off and now it turns over but won't start.checked for fire,engine is firing and the timing belt looks good.when it turns over it almost sounds like there is a drag to it.checked for codes and there are none.i'm at a loss.
Old 16 Jul 2013, 10:53 pm
You said the timing belt LOOKS GOOD.....Looks can sometimes be deceiving...It still could have jumped a tooth or two,thus it could be out of timing enough to cause your problem......Might want to read this just for educational purposes: Wont Start With Camshaft Sensor Hooked Up.....This seems to suggest that if the car will start with the Camshaft Position Sensor un-plugged it is definately out-of-timing,and more than likely the belt?(IMPORTANT NOTE!....By forcing the engine to run when you unplug the cam sensor, it provides a valuable clue, but you risk doing expensive valve damage.
Aka:~KILLER~
Old 16 Jul 2013, 11:20 pm
as i stated in the post earlier,i pulled it down and retimed it and still the same problem.i'm a mechanic by trade so i pretty much know the basics and have went over them twice as well as checking the wiring harness and plug ins.we've had this car for a while and it seems like we work on it more than we drive it.
Won't start cindylou Tech & Performance Forum 4 29 Apr 2012 06:23 pm
Won't start jimbowman69 Tech & Performance Forum 4 16 Apr 2012 06:05 pm
WILL NOT START bull Tech & Performance Forum 0 29 Mar 2012 05:33 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
Ran out of gas and now won't start Gracie512 Tech & Performance Forum 28 09 Jul 2009 10:15 pm
