P2302 Help
  • 1 Post By abusby
Old 14 Jul 2013, 02:40 pm
Default P2302 Help
I have a 04 pt with turbo giving a p2302 and running rough. I've put in new plugs and coil and the wires test good with a multimeter, around 3400 ohms. I've searched the web and can't seem to find anything else that it could be. Like a lot of people, I can't afford to take it to the shop. The only other thing I'm thinking is maybe a PCM, but I'm not sure. My Expedition was running similarly once and ended up being a vacuum leak so I thought about that and checked for that as well with not luck. I'm at a loss as to what to do next any help would be greatly appreciated. Thanks.
Old 14 Jul 2013, 02:54 pm
Default Re: P2302 Help
Check the wiring harness going TO the coil. From what I've read, the PCM could cause this issue, but it's the least likely thing.
Old 14 Jul 2013, 04:40 pm
I'm not exactly sure how to check the harness but I looked it over and didn't see any visible problems. I tried looking up how to test it but couldn't find anything.
Old 14 Jul 2013, 08:35 pm
Angry Re: P2302 Help
Ok so I went back and checked something I didn't before, I checked for spark and discovered I have no spark on 1&4 and then I also checked with the coil I pulled off and different wires and still the same. So one conclusion is certain, I bought a coil when I didn't need to, I guess I have a back up. So in looking up this symptom I've found that its either a short somewhere or a bad PCM. it looks like I'm going to have to tear into the harness to check further. Unless anyone has any other suggestions? Thanks again.
zamfir2 likes this.
Tags
2302, ignition coil, rough idle
Definitive Answers? P0300, P2302? GTCRUISER2006 Tech & Performance Forum 2 20 Apr 2013 06:07 pm
P2302 & crack in valve cover cnice352 Tech & Performance Forum 12 02 Oct 2011 06:00 pm
P2302, P2305 & P0300 sjzdx Tech & Performance Forum 5 26 Aug 2009 08:43 pm
