Cruise control stopped working
Old 14 Jul 2013, 04:08 pm
Default Cruise control stopped working
Hi can any one please help I recently purchase a mk1 2000 pt cruiser with faulty cruise control any suggestions
I press the lever to turn it on but there is nothing
Thanks
Old 14 Jul 2013, 05:01 pm
Default Re: Cruise control stopped working
You say it "stopped working" but in your statement you said you purchased the "MK1 2000 PT" (whatever the heck that is) with faulty CC. So, it was working for the previous owner but quit working and you bought it that way?
What did the previous owner try and do to fix it? Did he check for a bad vacuum? Did he check for a blown fuse? Does the "cruise" light come on in the dash but it doesn't engage?
What have you done to try and fix it? Are all the parts needed to have CC there and in working order?
Your question is rather vague without further explanation.
P.S. Please explain what a MK1 2000 PT is and why is it different from a normal PT?
Old 03 Aug 2013, 12:02 pm
ejstith's Avatar
Hey, Crewzin, where is the cruise control fuse. I couldn't' find it in the manual. Mine quit working too. When l push in the button the cruise just flashes & goes out. This just started, it always worked fine. Thanks.
2005 PT, Limited turbo Lite. Automatic all whistles and bells.
Old 03 Aug 2013, 12:13 pm
There are so many things that control the CC it's hard to tell you where to start. The PCM (Computer), Clockspring (in the steering wheel) Vehicle Speed Control Switch, Speed Control Servo, brake lamp switch, Clutch Pedal Position Switch (in the manual) and Transmission Range Sensor (in the automatic) and last but not least the TCM (Transmission Control Module).
Old 03 Aug 2013, 01:34 pm
Garya1682's Avatar
Send a message via Skype™ to Garya1682
Originally Posted by CREWZIN View Post
The cruiser control fuse in the 00-05 cruiser is the #10 fuse in the interior fuse box.
when I faced this issue it was the speed control servo and I changed the fuse for the sake of it and It solved the issue for. my cc light was coming on but it didn't do the job
2002 cruiser
2.0L PETROL AUTO
80k miles
Old 05 Aug 2013, 04:02 pm
ejstith's Avatar
Well I finished my trip without a cruise control & when I got home I checked the fuse & it was OK. I started checking around the servo & found the plug was disconnected. I just had the timing belt replaced & they failed to plug it back in. Plugged it in & all is well.....
Old 05 Aug 2013, 04:06 pm
randyincctx's Avatar
Thumbs up Re: Cruise control stopped working
Sometimes the obvious solution,is also the simplest...
Aka:~KILLER~
Old 01 Apr 2014, 08:59 pm
Hi! I just had my timing belt replaced and my cruise control isn't working.
Where is the servo and the plug you're talking about as I'd like to check that>
Thanks for your help!
Old 01 Apr 2014, 09:26 pm
cruserdad1976's Avatar
isnt there also a vacume line that is really little and easy to break(thats what happened to mine when they changed the TB
Solution for Cruise Control not working on 2006 PT Cruiser Touring Edition refbillyj General PT Cruiser Discussions 14 03 Apr 2015 04:17 pm
Installed factory cruise control but not working gitrdun Interior Accessories Forum 11 07 Jul 2013 10:14 pm
One more try... Cruise control not working... Jered General PT Cruiser Discussions 9 27 Jan 2009 03:04 pm
cruise control not working oldone Tech & Performance Forum 1 14 Oct 2007 09:50 am
Cruise Control not working glfnjim Tech & Performance Forum 14 27 Nov 2005 01:45 am
