Error Code 480 Help - Cooling Fan
Old 16 Jul 2013, 02:16 pm
Default Error Code 480 Help - Cooling Fan
Hi!
2003 2.4L Turbo - Error says Cooling Fan Relay 1
The high speed works - I can hear it when I go to shut off the car. Does this mean it is likely an electrical problem or should I plan on replacing the entire thing? It has not been overheating, but the freon is low right now.
Any help is very much appreciated!!
Old 16 Jul 2013, 04:56 pm
Default Re: Error Code 480 Help - Cooling Fan
P0480 is the dtc code for the low speed fan relay circuit, not the high speed. The low speed fan can be inoperative and the high speed still work. Should be two separate relays in the power center under the hood, and I think there is separate fuses for both speeds also. Next would be a bad fan motor, also common.
Old 16 Jul 2013, 06:38 pm
Being an 03 you have a PDC (Power Distribution Center) in the engine compartment. There is both the high and low speed relays. The high speed relay can be checked by swapping the horn relay and see if the horn is still working (not needed since you say you can hear the high speed). The Low speed relay sits by itself (see fuse box below) and you MAY be able to swap it with the Spare (J). Really not sure if the spare is really there or it's compatible with the High speed relay.
Old 22 Jul 2013, 12:46 pm
Thanks! I will try this tonite
We had to replace a fan on the wives PT
Old 23 Jul 2013, 06:23 am
I thought the turbo's had a variable speed fan? Turbo guys could help out here.
Old 13 Dec 2016, 09:51 pm
O3 tubo has no relays computer operated only. You will have to replace fan that is year specific only. Their is a write up in this forum about the 03 fan.
Old 13 Dec 2016, 09:58 pm
sorry old post
Need some help please with error code muzicmax General Turbo Discussions 6 11 Oct 2012 12:13 pm
Thanks for error code help mycar Tech & Performance Forum 3 11 Aug 2012 07:25 am
What does the error code PO 138 really mean? TheFox General Turbo Discussions 8 15 Jul 2012 10:10 pm
Error code 601 COOLSILVER02NV Tech & Performance Forum 7 14 Jul 2009 10:52 am
Error Code saldagus Tech & Performance Forum 2 25 Nov 2008 09:51 pm
