Traction control, ABS, and Brake lights stay on
Old 20 Jul 2013, 11:20 pm
Default Traction control, ABS, and Brake lights stay on
Several months ago, my son left the lights on my 05 PT Cruiser on and drained the battery stone cold dead. I jump-started the car from my Dodge RAM truck by connecting the jumper cables to the bolts indicated under the hood for jumping.
The car started right up without any problems; however, immediately the Traction Control, ABS, and Brake lights came on in the instrument panel. They've been on for 4 months now and they come on EVERY time the car is started.
Here's the rub: My Cruiser doesn't have ABS or Traction Control! Did the jump fry my PCM? I loathe taking it to my local Dodge dealer as they are not honest or ethical.
Thanks very much for any input you can offer!!!
Old 21 Jul 2013, 12:06 am
randyincctx's Avatar
Question Re: Traction control, ABS, and Brake lights stay on
Have you tried to pull codes from the OBD system?
Aka:~KILLER~
Old 21 Jul 2013, 07:08 am
Default Re: Traction control, ABS, and Brake lights stay on
Also try resetting everything by taking the negative battery cable off for 5 minutes. Step on the brake pedal. Put it all back together.
Old 11 Sep 2013, 12:58 pm
OK! Problem solved! After weeks of research and multiple visits to the dealer (yes I broke down and went in), turns out the problem is with the instrument cluster itself. During the jump process, a voltage surge toasted the circuitry in the cluster.
I was sure it was a cooked ECU/PCM, but I was wrong. Guess that's what I get for doing my own thinking.
Old 11 Sep 2013, 05:35 pm
Thanks for coming back and telling us what it was - and glad you got it fixed.
ABS Light, Parking Brake Light, Traction Control Light kupothechocobo General PT Cruiser Discussions 9 28 Feb 2017 01:56 pm
ABS and Traction control warning lights on ieatcake General PT Cruiser Discussions 18 10 May 2014 06:20 am
Nedd some help with Traction Control and ABS lights muzicmax General PT Cruiser Discussions 8 07 Jul 2011 09:21 pm
Traction Control? RaineMan General Turbo Discussions 3 21 May 2011 01:04 am
Traction control on or off? ryeguy666 General Turbo Discussions 11 01 Apr 2007 02:09 am
