Air Conditioner pressure from 0 to 45 in 2 seconds
Old 21 Jul 2013, 04:23 am
Default Air Conditioner pressure from 0 to 45 in 2 seconds
Hello PT owners. Can one of you guys help me solve my AC problem?
2004 PT Cruiser Base Automatic. The AC is not working properly. Here is what happened:
1. AC compressor wouldn't start. Only room temperature air was blowing. I had the AC set to the coldest setting and the highest blower setting.
2. I replaced the AC relay and the fuse in the box under the hood. I shorted the Low pressure switch. Nothing.
3. I hooked up an AC refill kit gauge to the low side port. The gauge was showing 0 with the AC on or off. I started to refill the AC and the compressor came to life.
Here is the problem: I turn on the AC and then the pressure climbs to 45psi, the AC compressor kicks on and then off dropping back to 0 psi. Then the cycle starts again. It takes about 2 seconds for the cycle to happen.
I STILL don't have cold air.
If the AC is in the off position, the psi is 55 which is why I stopped adding more.
I'm wondering what should I do? If I add more r134a I'll step into the warning/danger area of the gauge. But because I added more r134, I got the compressor to at least show signs of life. Anyone what the pressure should be while the AC is off?
Old 21 Jul 2013, 09:34 am
Default Re: Air Conditioner pressure from 0 to 45 in 2 seconds
Well AC forum diagnostic is not the best place for trouble shooting but generally seeking my best guess is a partially block AC orifice tube?
Old 21 Jul 2013, 10:48 am
I was just wondering this yesterday. Doing so research I found that the orifice tube has a certain amount of restricted flow in order to do it's job. But was wondering how much flow do these have?
Sorry to thread jack!
Old 22 Jul 2013, 10:48 am
The combined 134 can/gauge/fill kits are fine for someone who has some knowledge of A/C to top off a working unit, but can cause more harm than good if you aren't familiar with A/C systems. Personally I would hook up a set of real gauges AND a scanner and see if the pressures shown by the scanner match the mechanical A/C gauges, and what those pressures are. A bad hi side switch or wiring can also cause your issue. With proper gauge readings you can then diagnose the system.
Air Conditioner Air Conditioner Vaccuum or Flap seal issue??? RMThompson General PT Cruiser Discussions 7 25 Feb 2012 02:40 pm
engine runs for couple seconds, key off TD04PTGT General Turbo Discussions 6 14 Apr 2010 08:49 pm
Fan stuck in a loop, goes on for ~10 seconds, off for 10, repeat elvisjer Tech & Performance Forum 2 31 Jan 2009 05:34 pm
