Engine Problem 2008 PT Cruiser
  • 1 Post By Busa_Powered
Old 21 Jul 2013, 03:58 pm
Default Engine Problem 2008 PT Cruiser
Every couple of days the instrument panel goes wacky. The check engine light will come on and then the dummy lights come on and the car wont let me go over 2500 rpm. The temp gauge and the fuel gauge go up and down like they are possessed. In order to fix the problem I have to put the car in neutral and turn the car off and then on again which fixes the problem but the check engine light stays on for a while and the goes away. Any help would be appreciated. I went down to my local auto store to run a diagnostic and they said it needs a new PCV valve and a cam shaft position sensor. Is there anybody who has had this problem and got it fixed? Suggestions?
Old 22 Jul 2013, 05:29 am
Default Re: Engine Problem 2008 PT Cruiser
50; change the pcv valve anyway. The 2500 rpm limit is a sign of a cam sensor/magnet. Some PT ignition switches are possessed!
Old 22 Jul 2013, 06:14 am
Ray_Dockrey's Avatar
How old is your battery? A failing battery or bad battery connections can cause issues like this too.
Old 22 Jul 2013, 06:18 am
Thanks pto6, I'll go ahead and swap those parts out and see what happens. Cross my fingers.
Old 22 Jul 2013, 06:21 am
Its a 2008 PT and haven't put a new battery since I got it, what's the fail time on these batteries?
Old 22 Jul 2013, 07:45 am
My way of thinking is a battery can go anytime. Even new batteries fail. I would at least have it checked. On my 09 the battery was having a very hard time turning the car over on cold mornings but checked good. I replaced it.
How long have you had the car? If it is several years old it may be time to replace it.
Old 22 Jul 2013, 08:23 am
Welcome to the forum
are you going to stay and introduce yourself and post pics etc etc
Or are you just going to leave us, popping back in only when a new issue arrives? Thank God for the "forgot my password" option.
Chip18sw likes this.
Old 23 Jul 2013, 07:25 am
I just filled out my profile so I guess I am here for the long haul. I really appreciate you guys giving me good advice, I will implement your suggestions and hopefully will fix the problem.
Old 23 Jul 2013, 07:30 am
the PT is a 2008 and was purchased in 2010. The battery has been changed recently when the timing belt was changed. Could it still be a faulty battery?
Old 23 Jul 2013, 08:29 am
Hello 50, welcome to the forum.
Your in Orlando so there's plenty of AutoZone's and Discount Auto stores around. They along with others will do a free battery and system charging test for you. Might as well rule that out (for free) and if it's not the problem, go from there.
New Member with inherited 2006 PT Cruiser and engine light problem CruiserForMom Welcome New PT Cruiser Members 7 21 Jan 2013 04:47 am
Pt Cruiser Clutch + Engine ProbleM eponce Tech & Performance Forum 6 17 Aug 2012 10:14 pm
2008 PT Cruiser-Engine Lite question rbroadway General PT Cruiser Discussions 3 24 May 2011 12:42 pm
2008 PT CRUISER WHEN THE AIRBAG IS DEPLOYED DOES THE ENGINE TURN OFF? ilk42 Tech & Performance Forum 1 28 Jun 2010 09:20 pm
2008 brake or tranny problem aenima45 Tech & Performance Forum 1 06 Jan 2009 07:52 pm
