Wire diagrams , crank & cam sensors
Old 21 Jul 2013, 03:59 pm
Default Wire diagrams , crank & cam sensors
Anybody have some pics of the wiring diagrams for the crank and cam sensors on a 2002 Pt? Trying to locate a shorted wire. Any advice is appreciated.
Old 21 Jul 2013, 04:07 pm
UptownSport's Avatar
Default Re: Wire diagrams , crank & cam sensors
Yes, there's a 'Factory Service Manual' online.
Search 'PT Cruiser FSM PDF'
PDFTown had it ...
Old 21 Jul 2013, 04:58 pm
The cam sensor is a pretty short path and easy to follow, the crank sensor is much harder plus you need to crawl under to get at it.
Old 21 Jul 2013, 05:33 pm
Here ya go...
UptownSport likes this.
Old 21 Jul 2013, 06:51 pm
Thanks guys!
Old 22 Jul 2013, 04:26 pm
Default Re: Wire diagrams , crank & cam sensors BACK AGAIN
Hey guys. Ok, looking at the wires from the camshaft position sensor. I've uncovered half of them. The one to the PCM looks perfect. The other two which are black & blue, and Orange are the ones I'm curious about. I was thinking about bypassing them and hooking them directly where they go. The best I can tell from this picture is that the orange wire is the same orange wire that is on the crank sensor, but the black and blue wire I'm not sure where it leads. Any ideas from looking at this picture?
Old 22 Jul 2013, 04:32 pm
Looks like it goes to the PCM for a ground but also doubles as a ground for the Engine Coolant Temperature Sensor.
Might be wrong about that. Get conformation.
Old 22 Jul 2013, 05:13 pm
Since that wire is a ground,, then do you think the orange wire to the crank sensor is the wire with the problem?. If its a ground and its grounded then its probably not a problem, correct.?
Old 22 Jul 2013, 05:42 pm
Your theory sounds good BUT sounds too easy of an explanation.
Old 23 Jul 2013, 07:19 am
dickjonson; The wires go back to the pcm. --- Careful! --- the black ground wire may be an internal ground and NOT a body ground. All testing must be done with a digital meter! The electronics guys could help out here.
Many wire problems are caused by chafing or heat. Also, by wearing from the axle shaft of sagging wires.
PT Cruiser 2.2 crd WIRING DIAGRAMS Matteo77 General PT Cruiser Discussions 1 03 Jun 2013 01:28 pm
Ecm wiring Diagrams?? Wolfies Tech & Performance Forum 9 10 Jul 2012 02:55 pm
Vacuum Diagrams- 2002 PT sscanlan Tech & Performance Forum 8 14 Oct 2011 12:16 pm
where to find crank and cam shaft sensors. jaymeb21 Tech & Performance Forum 3 14 Mar 2011 03:22 pm
special tools / diagrams ?? surreyboy Wheels, Tires, Suspension 6 28 Aug 2009 06:12 pm
