No spark 1&4...
Old 21 Jul 2013, 05:40 pm
Unhappy No spark 1&4...
Ok so I have an 04 2.4L with turbo that is giving me a p2302. I have replaced plugs and coil,move tested the plug wires and they are good, I've tested the wiring to the coil and it is good. The only thing left that I know of is a bad pcm but everything I've been told is that is not likely. I am wondering, is there anything else that could cause ther to be no spark on 1&4? I can't afford to take it in to the shop let alone buy a pcm for it so I'm just trying to see if I'm missing something. Thanks.
Old 21 Jul 2013, 05:50 pm
Default Re: No spark 1&4...
Bad coil pack perhaps? (1 & 4 are companion plugs on the same coil).
Old 21 Jul 2013, 05:56 pm
Coil has been replaced.
Old 21 Jul 2013, 08:45 pm
I know this is obvious but, try double check cable seating? Maybe the new ones are a bit short?
Old 21 Jul 2013, 09:12 pm
The wires are fully connected.
Old 22 Jul 2013, 09:18 am
Ugh sounds like a real PIA, you have going on. It would seem that if you've changed the plugs and the coil pack the problem should be gone?
The only thing I can think of, is to swap wires again but not new ones swap the 1-4 wires to the 2-3 position and see if the problem moves?
Old 22 Jul 2013, 10:12 am
check the connector and inspect wiring before you go throwing a new computer at it. i've had a couple crappy connectors on my car that looked fine but did not work.
if it were me i'd move the wires in the electrical connector. swapping the wire that signals 2&3 to fire with the wire that signals 1&4 to fire, as well as swapping the plug wires to the corresponding posts on the coil. if the problem is still present, you'll know its from the connector back. from there you test the wire at the coil connector and the ECU. if it's good, you'll know the computer is not sending a signal.
i'm not a mechanic so i could be wrong on that, anyone want to correct me? i'm good electrically though, and this makes sense to try.
Old 22 Jul 2013, 10:21 am
cruserdad1976's Avatar
you know new coils can be and are many time bad
Old 14 Aug 2013, 07:38 pm
Well I got a hook up at the dealership and they looked at it for me for free and they say its the PCM, looks like I'm going to have to she'll out more money than I want on a car we've had 8 months. Wishing I would've got the aftermarket warranty now. Oh we'll too late.
Old 15 Aug 2013, 12:51 am
abus; check for a 0340 code. I don't know if the dealership computer can tell the difference between a bad pcm or a corroded connection. Like rob said, check the connectors. This might involve --- disconnecting the neg battery terminal --- removing the pcm --- unplugging and plugging the multi-connectors several times --- reinstall. With a wiring diagram and an ohmeter you could determine conductivity between the coil plug and the pcm plug.
Tags
coil, ignition, no spark, p2302
Spark but no gas........... fretless Tech & Performance Forum 10 18 May 2011 11:55 am
No spark, turns over but no spark? magic1021 Tech & Performance Forum 26 15 Sep 2009 07:50 pm
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
RE: Spark Gap kennybopaloo General PT Cruiser Discussions 13 04 Apr 2006 04:24 pm
Spark Gap kennybopaloo General Turbo Discussions 13 31 Mar 2006 05:09 pm
