Request for Alternator/Generator Internals
Old 23 Jul 2013, 12:54 pm
Post Alternator/Generator Internals and Part Numbers
Looking for information on the Alternator/Generator internals. So far I have found that it is either made by Denso or Mopar, the master part number for a stock PT seems to be: RL033253AA
Personally I am looking for the part number for the Rectifier-Diode (it seems it is one unit in this model). But having all the part numbers, breakdown, and others would be a great reference for anyone who wants to rebuild theirs instead of having a shop do it.
Oh, and if you have used a rebuild kit, I am sure others might appreciate a Vendor & Model number to search for.
To kick this off, from ALTERNATOR. Engine. Fits: CHRYSLER (2001-2011), DODGE (2004-2011), JEEP (2007), . # RL033253AA
ALTERNATOR. Engine. .
[BAN], [BAN] New Part For Core Return, After 05/01/2004. Stock Code RL033253AA ; 05033054AB; 05033054AC; 05033177AA; 05033177AB; 05033253AA
Manufacturer Chrysler
Categories Electrical > Alternators
Assemblies Alternator; Alternator [2.0L-ECC]; Alternator [2.4L-EDZ, EDV]; Alternator, [2.0L ECC]; Alternator, [2.4L-EDZ]; Alternators; Alternators [2.0L-ECC]; Alternators [2.4L-EDZ]; Alternators [ECC] 2.0L
For Models:
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 4-Spd. Automatic 2004, 2005
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 4-Spd. Automatic CONVERTIBLE 2005
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 4-Spd. Automatic CONVERTIBLE Touring 2004, 2005
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 4-Spd. Automatic Limited 2004, 2005
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 4-Spd. Automatic Touring 2004, 2005
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 4-Spd. Automatic,41TE 2002, 2003
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 4-Spd. Automatic,41TE HATCHBACK 4-DR 2001
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 4-Spd. Automatic,41TE Limited 2002, 2003
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 4-Spd. Automatic,41TE Touring 2002, 2003
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 5-Speed Manual 2002, 2003, 2004, 2005
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 5-Speed Manual CONVERTIBLE 2004, 2005
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 5-Speed Manual CONVERTIBLE Touring 2004, 2005
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 5-Speed Manual HATCHBACK 4-DR 2001
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 5-Speed Manual Limited 2002, 2003, 2004, 2005
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V SMPI, 5-Speed Manual Touring 2002, 2003, 2004, 2005
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V Turbo, 4-Spd. Automatic,41TE GT 2003
CHRYSLER PT CRUISER 2.4L 4 Cyl DOHC 16V Turbo, 5-Speed HD Manual GT 2003
CHRYSLER PT CRUISER 2.4L I4 DOHC 16V H.O. Turbo, 4-Spd. Automatic GT 2004, 2005
CHRYSLER PT CRUISER 2.4L I4 DOHC 16V H.O. Turbo, 4-Spd. Automatic GT CONVERTIBLE 2004, 2005
CHRYSLER PT CRUISER 2.4L I4 DOHC 16V H.O. Turbo, 5-Speed HD Manual GT 2004, 2005
CHRYSLER PT CRUISER 2.4L I4 DOHC 16V H.O. Turbo, 5-Speed HD Manual GT CONVERTIBLE 2004, 2005
Please note that this information is not in the Service Manual as I suspect it was viewed as out of scope for a regular mechanic.
Old 23 Jul 2013, 01:37 pm
Default Re: Request for Alternator/Generator Internals
Information From Denso for a search for 2003 PT Cruiser
Find My Part | DENSO Auto Parts
Trim/Engine
Part #
Part #
Notes
Trim: L4 (2.4L)
210-0558
LA990009-1420
w/ Turbo
Trim: L4 (2.4L)
210-4201
LA990009-1420
w/o Turbo
Also attached are links to Denso's Install and Troubleshooting instructions. (too big to upload)
Charging System Troubleshooting Tips
Denso Install Instructions
Edit: fixed table formatting
Old 23 Jul 2013, 01:40 pm
Nippondenso makes the turbo alt. Chrysler makes nothing, these things are contracted. The n/a alt is a different brand. If you want to buy parts online you will need the # on the lable of the alt. to look up parts.
Old 23 Jul 2013, 01:53 pm
That helped Busted_PT!
Exploded view of the Nippondenso Aleternator used in Chryslers:
Edit: NOTE, this is a general image not PT or Model specific
Edit: The exploded image is from:http://www.aspwholesale.com/ And they carry replacement parts as well. Currently seeing if they will help narrow down specific part numbers.
Old 23 Jul 2013, 02:23 pm
Note: This table seems to indicate the Non-Turbo is made by Mitsubishi
Code:
 Year  	Vehicle Make  	Vehicle Model  	Engine Code-Config-Cylinder  	Engine Liters  	Product Name  	Options  	Amp/KW  	Mfr. Part Number  	Manufacturer  	Lester
2003	CHRYSLER		PT CRUISER	L	4.00		2.40		ALTERNATOR	w/ Turbo	150	421000-015	NIPPONDENSO	11040
2003	CHRYSLER		PT CRUISER	L	4.00		2.40		ALTERNATOR	wo/ Turbo	100	A2TG0191	MITSUBISHI	13995
Code:
Manufacturer 	Series 	Description 	Part Number 	Mfr. Part Number
NIPPONDENSO	ER/IF	BEARING, BALL	10-2021-4W	949100-6730
NIPPONDENSO	ER/IF	BRUSH		38-8201		021660-0510
NIPPONDENSO	ER/IF	INSULATOR	42-82327	021605-3080
NIPPONDENSO	ER/IF	COVER		46-82700	021506-0070
NIPPONDENSO	ER/IF	WASHER, SPRING	46-82802	021542-0160
NIPPONDENSO	ER/IF	BEARING, BALL	6-303-4W	949100-2820
NIPPONDENSO	ER/IF	SCREW		85-1201		949007-7600
NIPPONDENSO	ER/IF	SCREW		85-1205		949006-5460
NIPPONDENSO	ER/IF	NUT		85-2300		949056-4910
NIPPONDENSO	ER/IF	NUT		85-2601		949056-2520
NIPPONDENSO	ER/IF	TERMINAL BLOCK	INP420		126220-0190
NIPPONDENSO	ER/IF	HARDWARE KIT-ND ER/IF		ND1-79-1100
NIPPONDENSO	ER/IF	REPAIR KIT-ND	ER/IF		ND1-79-11040
Old 23 Jul 2013, 02:27 pm
I found my Rectifier! Unfortunately I have not found the rest of the Mitsubishi part numbers yet.
From: Alternator & Starter Parts Wholesale - RECTIFIER-MI
Code:
Used On: (2005-03) Chrysler
Unit Nos: Chrysler 5033253AA; Mitsubishi A2TG0191, A2TG0191ZC
Lester Nos: 13995
Product Code: IMR8577
Price: $36.02
Old 23 Jul 2013, 02:48 pm
Specifications on the Mitsubishi Alternator
From: A2TG0191 Alternator,ER/IF,Mitsubishi,Alternator -Product Details
Code:
Product No.			AELS001-MI017
Wai No.				1-2545-01MI
Ref. No.			13995N
OEM				Alternator - Mitsubishi ER/IF
Power/Voltage			100 Amp/12 Volt
Pulley Type			CW, 4-Groove Pulley
		Interchange
AC-Delco			334-1514
AES				13995N
Chrysler			5033253AA
Lester				13995
PIC				203-482
Wai.No				1-2545-01MI
Wai-Ref				1-2545-01MI
		Applications
Vehicle Make	Vehicle Model	Year		Cylinder Type	Engine Liter
CHRYSLER	PT CRUISER	2005-03	L	 4		2.4L
And the Parts:
And a comment from the Site:
This Was Seen on the 2003-05 Chrysler PT Cruiser wo/Turbo. The Turbo Unit Uses a Denso 421000 Type Unit With Similar Mounting. This Unit Has a 4-Groove Pulley. According to Mitsubishi, This Unit Replaces the Earlier Used 13892. They May Interchange.
Code:
Part Type	Reference #	Karam #
BEARING         5-2310		10-879-4
BEARING         5-2802		6-101-4
BRUSH		7303-305	38-8305
BRUSH HOLDER	7403-3001	IMB735
PLUG CODE	9801-362
PULLEY		7900-1004
RECTIFIER	7703-3128	IMR8577
SLIP RING	7103-12         28-83852
STATOR          7203-8323	27-8307
TEST LEAD	9800-SK
WIRE & PLUG	9890-9040
Last edited by Caustic; 23 Jul 2013 at 03:08 pm. Reason: Added part number for Brush Holder
Old 23 Jul 2013, 03:34 pm
Yep, that's correct. I spent a ton of time trying to find a front cover for the nip. Not available.
Tags
alternator, generator, rebuild, reference
Race Auto with Billet Internals HiddenHippie craigslist 15 23 May 2013 01:09 pm
HHO generator mdskinner731 Tech & Performance Forum 18 25 May 2012 01:18 am
Battery light... Generator?? dgb Tech & Performance Forum 23 07 Feb 2012 06:54 pm
HH O generator notadodge Tech & Performance Forum 75 03 May 2011 11:34 am
Chrysler window sticker generator? What do I own? Calab Tech & Performance Forum 2 12 Oct 2010 03:07 pm
