CV JOINT REPLACEMENT
Old 23 Jul 2013, 04:49 pm
Cool CV JOINT REPLACEMENT
Hi, Has any one replaced there Cv joint on a PT Cruiser, I have a 2002 Manuel please call or email, 305 962 1495 Thank You; David
Old 23 Jul 2013, 05:35 pm
Default Re: CV JOINT REPLACEMENT
1 remove the hubcap and the cotter key in the axle, then the retaining cap and spring washer. loosen the big nut on the axle, remove it and the thick washer behind it.
2 loosen the lugs, jack up the car, take the wheel off
3 take out the two bolts that connect the hub to the strut, turn the steering wheel all the way to one side
4 pull the hub so the axle tip comes out of it (if it doesn't fit out, turn the steering wheel the other way)
5 put a pan under the trans to catch the fluid, and pop the axle out of the trans with a small prybar.(or large flathead)
that's it. should take you 15 minutes tops to remove and about 10 to put back in. you might also replace the $8 axle seal on the trans while you're at it. pops right out
Old 23 Jul 2013, 07:41 pm
Thumbs up Re: CV JOINT REPLACEMENT
Thank You. David
CV Joint?? 808 Wheels, Tires, Suspension 16 27 Mar 2015 04:12 pm
Ball joint replacement Tobymelodeon Wheels, Tires, Suspension 2 22 Apr 2013 12:21 am
Front Ball joint replacement Easy or Hard?? ab1 Wheels, Tires, Suspension 9 10 Sep 2012 01:15 pm
Ball Joint Replacement: Still having problems CarMah Wheels, Tires, Suspension 2 11 Jun 2008 09:07 pm
Bad ball joint replacement? Samson Wheels, Tires, Suspension 4 19 May 2008 05:40 pm
