WHAT THE??????
Like Tree5Likes
Old 24 Jul 2013, 06:12 am
Default WHAT THE??????
Good Moring PT world. I've been posting on here for several weeks about an on going problem with my 02 PT. After replacing a cam sensor 4 times, a crank sensor 3 times, tearing through wires, and a few other things,,,, I continued to get the same issue and code,,,, cranks and cranks for about 20 seconds then starts. The code was always the same, P0340, bad cam sensor. I decided yesterday that I was going to give in and take it to the dealer. I felt like I needed to drive it up and down my road just to see if it could make the distance. I had driven it with this code a few times before, but nothing changed. Last night I did do something different, I drove the car like I stole it. Spun a few tires and auto shifted at some higher RPM's. Nothing dangerous mind you, but I just wanted to see if it would die. It ran great for about 10 minutes back and forth down the 1 mile back road I live on. I decided that yes it could make the long drive to the dealer. I turned the car off and went inside for a bit. Came back out to move it, and it starts perfect! No excessive cranking! I grabbed my Actron code reader and cleared the code. Drove the car again, and turned it on and off several times. Starts and drives perfect. Just curious of why this issue of excessive cranking and engine code went away? Any ideas??
Old 24 Jul 2013, 06:59 am
Default Re: WHAT THE??????
I don't know about your problem, but I sure like your solution.
My mother used to drive her friends corvette while her car was getting fixed. The guy complained that she should hit the gas once n a while. Every time he'd get the car back a cloud would come out.
jondickson likes this.
Old 24 Jul 2013, 07:43 am
Default Re: WHAT THE?????? update
Ok, read the above post from me,, now read this. That was last night. Just went outside to start it, its back to doing what it did before. What would cause it to cure itself and start correctly by it being operating temp? Any ideas?
Old 24 Jul 2013, 08:56 am
Disconnect the battery and unplug the computer. PCM. And see if that helps.
Old 24 Jul 2013, 10:20 am
cruserdad1976's Avatar
maybe dirity injectors????
Old 24 Jul 2013, 12:36 pm
Don't think that will cause the 340 code though. Some one else is having similar issue has unplugged his and seem to have gone away.
Old 24 Jul 2013, 12:53 pm
Ill try the unhooking, id like to go ahead and clean the injectors. Whats the best way to do that, or does it have to be done professionally?
Old 24 Jul 2013, 01:19 pm
Maybe someone will do you a favor and steal it
Old 24 Jul 2013, 02:53 pm
Yep but.. how far would they get?
Couldn't resist! Intermittent problems are a real bear! It this point I would try a DVOM on the sensor's the ECU are saying my be the problem and wiggle the harness at the connection points maybe it's a broken wire or loose wire somewhere?
Old 24 Jul 2013, 03:22 pm
Keys are in it! Lol.... Ive drove this thing all day. Stop and go, off and on. No issues what so ever. To me its something that once its warmed up, its good. I would think if it was a short it would do it regardless.
