Broke that darn fuel supply line today...
Old 26 Jul 2013, 05:16 pm
Send a message via AIM to BillsCruiser
Default Broke that darn fuel supply line today...
...Got tired of my '05 throwing a P0128 Check Engine code so I set out this afternoon to replace the thermostat.
Seemed simple enough...WRONG!
While lifting the stat housing up just high enough to get at the thermostat, I broke off the plastic fuel hose right at the fuel rail fitting.
Called around the local Chrysler Dealers...nothing in stock.
So now my PT will sit until a new firewall to fuel rail line arrives late Monday afternoon.
BTW...the original thermostat was stuck open. I suspected as much, this car takes way too long to warm up. Hopefully this will now correct the CE code showing up.
Only attempted this because I replaced both upper and lower engine mounts in about 1hr this morning and it all went SO well...
Old 26 Jul 2013, 06:50 pm
Default Re: Broke that darn fuel supply line today...
Ugh! But yeah that's where mine bites me in the butt! Your doing something simple and then bam something stupid appears!
Welcome aboard and...now you know!
Old 27 Jul 2013, 04:14 am
That firewall to fuel rail line couldn't have been put in a worse spot...always in the way. It is a plastic piece of crap.
Have said this before, but back in the old days with a low pressure fuel system (5-6 psi) the lines were steel with threaded fittings...nowadays, high pressure fuel systems (60 psi) have crappy plastic lines and fittings...go figure.
Old 27 Jul 2013, 07:57 am
Yeah, my heart sank when I heard that plastic snap.
I agree...a simple fix in the "good old days".
Now the car will sit for a few...
Turbo oil feed/supply line mole General Turbo Discussions 5 07 May 2013 12:15 am
what size is fuel line from firewall to fuel rail chitownpt Tech & Performance Forum 2 18 Mar 2013 06:17 pm
WTB: nylon fuel line dpmeeks Classifieds: Want To Buy 4 24 Sep 2011 07:14 pm
turbo supply line 4SPEED General Turbo Discussions 6 01 Mar 2011 05:32 pm
turbo supply line question 4SPEED General Turbo Discussions 2 01 Feb 2011 12:51 pm
