Been through the list and I can't spend the money!
Old 27 Jul 2013, 11:21 am
Default Been through the list and I can't spend the money!
I've been having cooling problems lately and have checked just about everything. My 2001 had a new head, pump and timing chain installed 25,000 miles ago. The fan works on both speeds, I've "burped" it twice, there is no sign of coolant in my oil (it's very clean) and the tstat seems to be working just fine (top hose gets hot as the fan kicks on to cool). I'm stumped and don't know any mechanics that I trust to figure it out. Could the radiator be clogged and only be allowing the coolant to flow through a small portion? I don't know what else to check at this point.
Old 27 Jul 2013, 04:19 pm
randyincctx's Avatar
Lightbulb Re: Been through the list and I can't spend the money!
Has it possibly had HOAT/OAT coolant mixed with Ethylene-Glycol antifreeze?;I have read that you shouldn't mix HOAT/OAT antifreeze with Ethylene-Glycol antifreeze.......End result can be a jelly like substance that can gum up the works in your cooling system,possibly clogging the heater core and radiator.(see photo)....Also;If water contaminants are present it can cause problems...Water (typically tap water), when added to engine coolants, introduces another group of contaminants to a cooling system. Contaminants such as chlorides and sulfates can actually attack non-ferrous metals (copper and brass) in the cooling system.....Hard water will promote scale deposits and can cause silicates to fall out of solution, producing a “gel” that can clog passageways in the radiator and heater core.
This is just one example of what happens when HOAT/OAT is mixed with Ethylene-Glycol......If this is just the thermostat,imagine what happens to the rest of the engine: radiator/heater core/water pump/and even 'water jackets' in the block & head.Do Not Mix OAT's and EG's Antifreeze
Aka:~KILLER~
Old 27 Jul 2013, 04:26 pm
Some people report that the jelled goo may be difficult to remove from the cooling system. Other people report that the issue was resolved by standard technique chemical flushing of the cooling system and rinse with lots of clean water, and they had no residual cooling problems for long term. Perhaps some people are luckier than others, or maybe it's easier to clean out when done early.I suggest you back flush the heater core and radiator, and be sure they flow freely. If there are any clogs in the radiator you might feel cool spots on the core while running. Radiator and heater core can also be hot tanked (boiled out) by a local radiator shop. Source: Do Not Mix OAT's and EG's Antifreeze
Aka:~KILLER~
Old 27 Jul 2013, 06:03 pm
UptownSport's Avatar
Default Re: Been through the list and I can't spend the money!
Assume it's overheating;
When it's idling?
At Highway speeds?
Both??
Sure, flush radiator, or stick Garden hose in top and see if flows out bottom.
Could turn heater up, that's what I do!
Old 27 Jul 2013, 06:07 pm
Here are some more shocking photos in this thread: Why HOAT? The PT radiator coolant thread...
Aka:~KILLER~
Old 27 Jul 2013, 07:25 pm
It starts overheating when idling and while driving. Pulled the tstat and put it in some boiling water and it opened right up. The upper rad hose gets nice and hot when the fan kicks on (tstat opens) but the lower hose doesn't feel like it changes temp. at all. Gonna try to flush the system and go from there.
Old 27 Jul 2013, 07:46 pm
Attachment 8552
That"s not a mix. The color is to pure. That's got something else in it. A lot of assuming gets published as fact on the internet. Especially when promoting a certain product. Most likely some type of low end stop leak. Try a new cap if you haven't. Also check the over flow hose, that it is tight and not leaking.
Old 27 Jul 2013, 07:49 pm
i had a similar problem with over heating, the temps i got when testing the radiator suggested it was clogged.... i found a brand new radiator for $60.00 on ebay with free shipping
Old 27 Jul 2013, 08:07 pm
Are you loosing coolant? Is the heat gauge showing normal?Does it heat if your using the ac?
Old 27 Jul 2013, 08:35 pm
Question Re: Been through the list and I can't spend the money!
Actually that link is for MGA(small British car) enthusiast's(just like us and PT Cruisers)...And the poster does go on to say: "I found some jelled coolant, and don't know what it is from. The radiator core was replaced last year and I am not sure what they used or put in with the coolant. I have flushed out the radiator and the block and head have now been hot tanked. Do you think I have any cause for concern?".......But since 'madeupofwires' asked if it could be clogged,and what could cause clogs.
Aka:~KILLER~
Dont spend money on the K&N bucksfan1976 Tech & Performance Forum 11 01 Aug 2011 10:43 pm
$5k to spend... but with restrictions emr131 Turbo Performance 10 14 Jul 2005 08:41 pm
200 TO SPEND, WHAT SHOULD I GET?? wfo57 Turbo Performance 13 28 Mar 2005 04:24 am
Before i spend the big bucks. technobear Tech & Performance Forum 9 11 Jul 2004 02:22 am
How should I spend my money!!?? yobiebs General Turbo Discussions 5 09 Jul 2003 03:06 am
