Cruise control ?
Old 27 Jul 2013, 11:57 am
Default Cruise control ?
Hi can any one please help I recently purchase a mk1 2000 pt cruiser with faulty cruise control any suggestions
I press the lever to turn it on but there is nothing. Only the "cruise" light come on in the dash ?
Old 27 Jul 2013, 12:22 pm
Default Re: Cruise control ?
After you reach the speed you want the engine to hold and you push the stalk IN to turn on the cruiser light, are you pushing down on that same stalk to engage the cruiser control?
You just don't push the button (that only turns on the light). Push DOWN on the stalk to make it work.
While in cruise, if you push UP on the stalk it should raise the speed by 1/2 mile per hour. Pushing DOWN will lower the speed.
To turn it off, press on the brake pedal or push in the button to turn off the cruiser light.
All this is in your owners manual.
Old 27 Jul 2013, 02:26 pm
Yes, I push DOWN on the stalk, but doesn't work. Just the cruiser light turn on. Nothing happens?
Old 27 Jul 2013, 02:33 pm
The fuse for the Cruse Control is the #10 fuse in the interior fuse box in the GEN1 cruisers.
Well then, you have to check the servo to see if it's connected properly and the cruise control wiring next to the throttle control wiring to see if it's working.
The servo is the silver triangle piece in the upper left hand corner of the engine bay...
The throttle and cruise control wiring run together on top of the engine...
Cruise Control chasjr1450 Tech & Performance Forum 4 13 May 2012 07:15 am
cruise control remington Tech & Performance Forum 3 19 Sep 2011 05:41 pm
Cruise Control blown05gt Tech & Performance Forum 0 17 Apr 2011 09:42 pm
Help please, cruise control adamw General PT Cruiser Discussions 7 30 May 2009 12:33 am
cruise control CloughBrengle Tech & Performance Forum 6 04 Jan 2009 04:38 pm
