codes codes and more codes
Old 27 Jul 2013, 04:41 pm
Default codes codes and more codes
hello all that have suggestions that can and may be able to help, I have a 2001 pt crusier limited and a few weeks ago making a right turn in 85 degree heat my car went dead, first code popped up was p1391 wasn't aware that the crankshaft sensor had to changed from a dealer part ONLY (Mopar), changed that,car runs fine A-1,untill it warms up temp.gauge still in the middle car shakes sputters and die, changed the cam sensor as well,,,that did no good, today I have new codes one about the battery being changed in 50 starts and the other is p320 about crank not being found in pcm.....HELP!!!
Old 27 Jul 2013, 04:46 pm
randyincctx's Avatar
Exclamation Re: codes codes and more codes
Have you checked the wiring & connectors all the way,even on the backside of the engine?
Aka:~KILLER~
Old 27 Jul 2013, 04:51 pm
Default Re: codes codes and more codes
yep done that still have the factory coating on the nothing draping or touching anything it isn't suppose too.
Old 27 Jul 2013, 04:59 pm
I was told from a Chrysler dealer yesterday that my o2 sensor and my intake air value or sensor could play the role of making the car proform the way it does
Old 27 Jul 2013, 05:13 pm
Have you tried doing a 'reset' to clear any codes,and then see if they return again?
Aka:~KILLER~
Old 27 Jul 2013, 05:18 pm
your's being a 2001, and i believe this only happens to 2001, check to see if the wiring harness going to the bottom of the alternator is hanging unusually low. it tends to rub on the drive axel and chafe. you'll probably see an eyelit that looks like it should be bolted to something holding the harness up.
wore the outer skin of the harness clean through on mine and exposed bare wires. not sure if the wires were shorting during movement or not. stripped 'em and soldered 'em and taped 'em. no problems since.
just something to consider.
2016 Kia Soul Plus Black
Old 27 Jul 2013, 05:22 pm
done that also codes return, but I noticed that when the car is cool and not been running it starts and drives fine for 10 to 15 minutes then cuts off,i had problems in the past with the car over heating a week prior coolant disappears whether it on the cool line or the hot line in the resoivor
Old 27 Jul 2013, 05:24 pm
thanx soyomb I will go outside and have a look,i will keep everyone posted whether this was successful or not
Old 27 Jul 2013, 05:26 pm
Question Re: codes codes and more codes
When the CPS was replaced with Mopar part,was the 'Target Magnet' also replaced?
Aka:~KILLER~
Old 27 Jul 2013, 05:32 pm
I already asked if you had checked the wiring for the sensor(s) from END-TO-END???
That was your response???
Aka:~KILLER~
Dash codes--not the usual OBD codes--help! chitowncruiser General PT Cruiser Discussions 5 01 Mar 2013 11:56 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
Codes? BladeRunner Tech & Performance Forum 4 12 Apr 2011 10:07 pm
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
