02 pt touring wont start
Old 27 Jul 2013, 07:01 pm
Default 02 pt touring wont start
i have a 2002 pt cruiser that had an over heating problem when i bought it, changed the thermostat and put coolant in instead of water and it took care of the problem until i noticed the water pump leaking. so i changed it and the timing belt since i was in there, it started twice and then just died on me, i have resest the timing 4 times and put in new coil, cam, and crank sensor. it acts like it want to but still wont start, what else could it be ?????
Old 27 Jul 2013, 09:33 pm
Default Re: 02 pt touring wont start
Are you getting the engine light coming on to help with the diagnosis?
Have you checked the spark and fuel pressure since you changed all those parts?
Old 27 Jul 2013, 10:06 pm
i haven't checked fuel pressure but i can hear the fuel pump turn on with the key and smell fuel after attempting to start it a couple times. and was unable to check spark after changing all those parts since i was working on it by myself today, that was my next step (spark) it was yellow or weak before, could it be the pcm????
Old 27 Jul 2013, 10:12 pm
randyincctx's Avatar
Exclamation Re: 02 pt touring wont start
It was running/starting up to that point.....Then:
Even if the timing is off by 1 degree/or tooth it could cause a similar problem.
I would suggest you check the timing alignment at least 1 more time....ONLY,this time put aside anything you have been using as a reference so far,and use the following photos as your example.(these are fast becoming the go-to Cam/Crank/Timing EXAMPLE photos from: Busted_PT)If everything is lined up EXACTLY like these photos your timing should be PERFECT,if not....well,you know what to do.
Originally Posted by Busted_PT View Post
Aka:~KILLER~
Old 28 Jul 2013, 10:07 am
Yep that is the exact photo i pulled off of my school data base and set the timing too. it cough and sputters acting like it wants to start but doesn't. i dont understand why it started the first couple times, once to make sure i had it right and the other to bleed the power steering pump, then nothining..... if the timing was off the first time could it have bent a valve????? or are the pcm known to just quit like that ????
Old 28 Jul 2013, 10:20 am
i will check my marks once again, this will make it the fifth time, im actually getting pretty fast at it now....lol but there is no lagg in the cranking. i will also check my spark again
Old 28 Jul 2013, 05:53 pm
It's possible. The valves can't hit the pistons, but they can hit each other. It's extremely unlikely, though.
Sounds to me like it's out of time. When you lined up the marks, did you use a straightedge through the center of the cam bolts? I didn't, and I got it wrong the first time. It looked like the marks lined up, but when I used the straightedge, I could see they weren't.
Old 29 Jul 2013, 11:09 pm
i did use a straight edge when lining them up. the half mark and the full mark in the middle that are suppose to line up are half a tooth above the straight edge when i line it up with the outside marks, that is how it shows it in the diagram i got from the data base. please tell me thats wrong so i can put this thing back together.
http://0-arrc.ebscohost.com.library....1-0.inline.gif
not sure if this pic showed up or not, its on my school data base. i am ready to buy a compresion tester once i finish these next three days of school and can get back to it. ty guys for all the help. i welcome any and all suggestions on what is causing this
Old 09 Aug 2013, 04:44 am
DL; note the pictures in post #4. --- The crank picture is perfect. --- The camera angle on the cam sprockets shows it off a little, but it's correct if you looked straight on. Pull a piece of twine between the centers of both bolts to check the inner marks.
DISREGARD the outer marks! --- Arrows UP
Old 22 Aug 2013, 11:43 am
i will do that..... did a comprssion test and only had 90lbs in cylinder 2 & 3 so i pulled the head and could see where the valves tapped the pistons..... just got it back from the shop and am about to put it back on...... i guess that answered my question on if its an interferance engine or not..... lol the hard way. ty guys for all the help
pt wont start gee77060 Tech & Performance Forum 13 13 Nov 2014 09:14 am
02 PT WONT START sgtwsky Tech & Performance Forum 2 15 Jan 2014 05:39 pm
I NEED HELP! CAR WONT START! AshHow Tech & Performance Forum 6 17 Dec 2012 01:22 pm
Car Wont start!! txgalant8 Tech & Performance Forum 6 06 Nov 2012 07:45 am
2006 Touring Ed. wont start.... help!!!! marvinev General PT Cruiser Discussions 4 18 Feb 2010 06:42 pm
