Timing belt question
Like Tree2Likes
Old 30 Jul 2013, 08:15 am
Default Timing belt question
Changing nightmare: 2002 2.4 L Timing belt
Question: Is it possible to install belt 360 degrees off? In other words, is it for sure OK so long as the crankshaft pulley and crankcase mark are aligned and the camshaft pulleys are properly aligned under tension? Or can the crankshaft pulley be off by 360 degrees and everything look A-OK?
Old 30 Jul 2013, 09:03 am
Default Re: Timing belt question
If the crank is on the mark and the cams are lined up withe the up arrow pointing up you are good. The arrows are the key on that. If you are unsure post pics of yours and we can tell you if your OK..
Old 30 Jul 2013, 03:19 pm
I think he means TDC Intake versus TDC Exhaust?
Old 30 Jul 2013, 03:49 pm
A full rotation is 360 degrees which would mean you are back at zero...
UptownSport likes this.
Old 30 Jul 2013, 03:57 pm
As long as you have all the marks lined up with both arrows on the cam sprockets pointing the same direction you will be in time. No matter if that's up or down on the arrows.
Old 30 Jul 2013, 09:25 pm
UptownSport's Avatar
Even if you installed belt with both cam gears pointing down (the "up" upside down) it'd return to correct or "up" on next crank rotation.
Old 30 Jul 2013, 09:49 pm
Just keep both arrows going the same direction.
Old 30 Jul 2013, 11:43 pm
randyincctx's Avatar
Thumbs up Re: Timing belt question
Here's photos of what it looks like when everything is perfectly lined up.......Can't miss!
Originally Posted by Busted_PT View Post
That is what your talking about...Right?
Aka:~KILLER~
Old 31 Jul 2013, 08:12 am
Thanks all. I think I am good.
My basic question is this...since the crank turns twice (720 degrees) for every full camshaft rotation, could you line everything up but the crank be 360 degrees off? I think the posts make it clear that if the crank arrow points to the reference mark, and the camshaft marks are aligned as shown, it has to be right. Thanks to all.
Another way to say it, since it is a 4-stroke engine, could you mis-install the belt to #1 TDC on exhaust stroke rather than #1 TDC on compression stroke?
I think you guys are saying that is not possible.
Old 31 Jul 2013, 12:40 pm
To hazard a guess, what would happen is your piston sequence would be switched. I am not aware that it would affect a gas engine with an ecu though since the injectors and spark would change sequence to match.
A guess on my part though, I am not a mechanic, just a dabbler.
timing belt question rob619 Tech & Performance Forum 3 09 Nov 2012 01:45 am
timing belt question. Crid Tech & Performance Forum 9 05 Apr 2012 04:01 pm
Timing belt question maddyfan171 General PT Cruiser Discussions 9 19 Aug 2011 11:03 pm
Another possible timing belt question PTBlue_2002 Tech & Performance Forum 2 16 Jun 2009 06:51 am
Timing Belt Question bmore25 Tech & Performance Forum 2 28 May 2008 11:43 am
