replacing all wires tied to crannkshaft to pcm
  • 1 Post By butterfly_pt_01
Old 30 Jul 2013, 08:30 am
Default replacing all wires tied to crannkshaft to pcm
I was wondering when I have to change the burned wires to the crankshaft sensor to I have to replace the whole harness with all the other the wires leading to the PCM
Old 30 Jul 2013, 09:37 am
Default Re: replacing all wires tied to crannkshaft to pcm
I would guess it all depends on how the wires were burned. When my Camshaft wire harness dropped down and burned the wires, the Chrysler dealer I was towed to was all set to change the sensor and wiring harness. The mechanic put it on the lift (broke one whole side of my undercar LED's, but that's another story) looked at the harness and soldered the burned wires back together. Wrapped them up real good and it's been that way for half a dozen years without a problem.
If your harness burned because a surge of voltage went through the harness, then probably the whole harness needs to be replaced. If the harness burned at one spot taking out the Crankshaft wires only, fix or replace just those wires.
Old 30 Jul 2013, 11:11 am
If you repair the harness. Make sure you solder them back. And tape or use heat shrink to protect from weather and getting against something and shorting. Twisting them together will be a nightmare.
Old 30 Jul 2013, 02:44 pm
If you are going to the trouble, I would add a few inches to give more slack, and use adhesive lined heatshrink over the solder joints and then tape over that. Should be the last time you ever need to make that repair if you hang them away from all the badness.
Old 30 Jul 2013, 09:28 pm
UptownSport's Avatar
an entire harness is $$$. Don't look it up as you will drop.
Old 04 Aug 2013, 11:00 am
Thanks guys I soldered them shrink wrapped as well found out that my ground wire to the alternator was burned just the same CRAZY!! burned thew two battery s and a alternator as well,car runs like a champion...selling a factory Mopar sensor as well If anyone knows anyone who may need one
UptownSport likes this.
Old 04 Aug 2013, 02:01 pm
randyincctx's Avatar
Lightbulb Re: replacing all wires tied to crannkshaft to pcm
I would personally say,hang on to is JIC....But,if you really want to sell it,go to the classifieds thread,and put the title "F/S PT Cruiser CRankshaft Sensor NIB".....You'll get more bites on it,this isn't the correct thread for people looking to buy.(They may miss it here.)
Aka:~KILLER~
Old 04 Aug 2013, 02:18 pm
Wink Re: replacing all wires tied to crannkshaft to pcm
Be sure to go here and introduce yourself,and post a photo(or photos)of your PT Cruiser: Welcome New PT Cruiser Members - PT Cruiser Forum We really like to see pictures of other members PT Cruisers!
Aka:~KILLER~
Replacing plugs/wires on 2006 non-GT Sita Turbo Performance 12 28 Jan 2012 06:48 pm
replacing TCM Bentron General PT Cruiser Discussions 15 19 Jun 2011 03:17 pm
ENGINE: is it serialized and tied to the VIN? oldorange Tech & Performance Forum 2 07 Sep 2010 05:50 pm
Its tied around my neck like a dead albatross TexasPriest General PT Cruiser Discussions 11 31 May 2009 01:06 am
Replacing Spark Plug Wires LT Almond GT Turbo Performance 4 08 Jan 2004 10:49 am
