P0620 code help please
Old 01 Aug 2013, 06:12 am
Tobymelodeon's Avatar
Default P0620 code help please
Hi,
Very occasionally when the fuel warning alarm goes off for low fuel, the engine management light comes on... It's showing as code p0620 - generator circuit malfunction. Seems strange that it only happens then and only very occasionally (twice in 2 months) if I stop the car and take the keys out for about a minute, then restart... Problem solved... No warning light but its bugging me now... I like things to be right!
I'm a complete novice when it comes to electronic gadgetry, but happy to have a go. Any advice and comments great fully received... What should I check first?
Thanks
2002 PT Cruiser CRD in Bright Silver.
Current Upgrades
Chrome door handle cups, chrome pillar covers, tinted windows, custom vinyl flame decals, alloy wheel decals, Enrgy bush kit, Engine cover MOD, LED Side Repeaters
17" Ace Manta Alloys, Red Brake callipers, Front grille MOD
Project list (wish list)
Rear bumper mod to DIY roll pan
Custom paint job (probably purple front end with flames running into the silver)
Air intake upgrade...
Old 01 Aug 2013, 07:12 am
Default Re: P0620 code help please
Toby,
Tried a search and can find no correlation why the "generator" fault light would come on when your low in fuel but allow me to pass on some information I received a long time ago when we had a mechanic (with his own shop) as a member of this forum.
The fuel pump is in the bottom of the gas tank. The gas itself not only cools the pump but also lubricates it. One too many times of letting the fuel drop down to where the warning light comes on can severely damage (burn out) that pump. A new pump is around $300 plus the labor to replace it not to mention that if it does burn out, it will be like your battery going dead, it'll never happen at a good time and will leave you stranded when it does.
Old 03 Aug 2013, 12:44 pm
Great advice there and noted, I'm a sod for running on fresh air!!
Old 04 Aug 2013, 04:42 pm
Just filled mine to the brim and added a healthy dose of Redex!
Current Upgrades
Ecc code jondickson Tech & Performance Forum 0 29 May 2013 11:22 am
Help with one code galeana77 Tech & Performance Forum 5 22 Mar 2013 08:27 am
CODE P0339 NOW, NOT "ALL" FIXED CODE YET HarleyTom Tech & Performance Forum 0 14 Nov 2012 03:23 pm
Code ? 1lowufo Tech & Performance Forum 1 25 May 2010 06:25 pm
code 352 coco1476 Tech & Performance Forum 5 18 Jan 2010 05:19 pm
