transmission or computer?
Old 01 Aug 2013, 03:48 pm
07CruiserinMO's Avatar
Default transmission or computer?
I had a bad camshaft sensor, and let it go for awhile. I noticed yesterday when I was driving it, it would drive fine at first, but then the RPM's would be high but I could not accelerate, then all of a sudden, it would jump and drive fine for a bit. if I stopped and restarted the car it would be fin for a mile or so, then it would repeat the issue. I drove the short distance to my destination, and about 2 hours later, I went to drive it again. it initially drove a block, then at a stop sign, I hit the gas and NOTHING. the engine would rev, the RPM's would go up, but it would not move. got it parked, changed out the camshaft sensor thinking that was causing the problem (I dont know crap about cars, just knew it was bad and I have had decreasing performance for the last week, starting it and no acceleration, but would run fine once I got at a steady speed). Got in the car, it started right up, put in drive, and again, nothing. my dad got in, put it in low gear, it went forward, he bumped it into drive, no issue. I get back in it, again, nothing. he got in again, and he put in drive an again, nothing, it just rolled back a bit as we were on a slight incline.
we did NOT disconnect the battery when changing the sensor.
thoughts?
Old 01 Aug 2013, 08:58 pm
Default Re: transmission or computer?
I am by NO MEANS an expert here, but i had that happen to my car a few times where it would "stick" like that- turned out i was very very low in transmission fluid. (I have a slow leak). Just a thought, though i am sure someone much more knowledgable in car repair what-not will be along.
Old 02 Aug 2013, 01:33 am
randyincctx's Avatar
Question Re: transmission or computer?
Have you checked the transmission fluid level,and the condition of it?(dark looking?,burnt smell?)
Aka:~KILLER~
Old 02 Aug 2013, 08:33 am
My dad checked the fluid, level was good, he didnt say if it looked dark or smelled burned.
Old 02 Aug 2013, 09:14 am
It's not throwing any codes either,right?
Aka:~KILLER~
Old 02 Aug 2013, 10:12 am
I couldnt get it down to a shop to diagnose. The last time i had it checked, it was just the code for the camshaft sensor.
Old 02 Aug 2013, 11:24 am
Lightbulb Re: transmission or computer?
PT Cruisers have a built in OBD system.....
Aka:~KILLER~
Old 02 Aug 2013, 01:30 pm
Okay, thank you so much! That is awesome, I never knew that!
Old 02 Aug 2013, 01:57 pm
Thumbs up Re: transmission or computer?
I wasn't sure....
Aka:~KILLER~
Old 02 Aug 2013, 03:41 pm
Is it possible the extended use of the car with the bad camshaft sensor put the car in limp mode? Might explain why it would run fine briefly after restarting it, and why we could only get it to run in low gear after replacing the sensor without disconnecting the battery.
Do I REALLy need a new Computer???? flwrchk Tech & Performance Forum 11 26 Jul 2012 01:26 am
computer chip or after market computer?? mdskinner731 Tech & Performance Forum 3 08 Nov 2011 02:08 pm
