Engine Torque Struts
  • 1 Post By rob342
Old 05 Aug 2013, 05:44 am
Default Engine Torque Struts
Well, after the valve job and timing belt my little PT runs like a top. Except for a nasty shake about 55 to 65 mph. Hmm. I am getting all sorts of diagnosis from transmission to axle shafts. But one that intrigues me is that I didn't know there was a setting on the torque struts. Could this be the reason for the shake?
Old 05 Aug 2013, 08:27 am
Default Re: Engine Torque Struts
What do you feel and what do you feel it through? Steering wheel shaking. Brake pedal or does it change if you use the brake?
Old 05 Aug 2013, 09:47 am
first step towards finding out whats shaking is to rotate the tires. put the front tires on the back and go from there. usually a shake at a certain speed is a tire problem. carefully inspect them for lumps and flat spots when you do it.
randyincctx likes this.
Old 05 Aug 2013, 05:50 pm
Please let me know if you ever find a solution to this problem. I have a 2006 with a manual transmission in it. So far, i've replaced both CV Axle's, outer tie rod ends, left wheel bearing, tried 2 sets of tires, and motor mounts, and I still have a nasty shake in the front end between 50-60, only when i'm accelerating. As soon as I let off of the throttle, the shake goes away. My local trusted shop is completely stumped, and we're not excited about throwing more money into the problem without getting any resolution.
Old 05 Aug 2013, 07:01 pm
randyincctx's Avatar
Question Re: Engine Torque Struts
Have you had anyone look at your torque struts/bushings?
Aka:~KILLER~
Last edited by randyincctx; 05 Aug 2013 at 07:13 pm. Reason: responding to 1st poster
Old 05 Aug 2013, 07:15 pm
Lightbulb Re: Engine Torque Struts
That's also another simple thing to look at doing.....
Aka:~KILLER~
Old 06 Aug 2013, 05:30 am
No shaking in the steering wheel or when braking. It when accelerating between 55 and 65 mph. It will shake the GPS off the dash. Once cruising its fine unless you give it a little gas. It did it before the valve job, just not as bad, so that's why im leaning toward the torque struts. Well, Tires are new less than 5000 miles on them. Kind of side to side, up and down shake
Old 06 Aug 2013, 08:39 am
TurboDucky's Avatar
Sounds like an axle problem. I know you said you replaced them - I went through three "reman" axles from Advanced Auto before I got a good one.
I actually had both sides giving me grief. One side shook with power on, the other side did it while decelerating. Took me a while to figure that one out.
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Engine mount/ torque struts BigApple Tech & Performance Forum 9 02 Oct 2017 11:22 am
torque struts 4SPEED General PT Cruiser Discussions 4 17 Apr 2012 09:11 am
Struts, torque info Afitch628 Wheels, Tires, Suspension 8 18 May 2011 11:04 am
lower torque struts adjustments cruizinla Tech & Performance Forum 5 14 Oct 2009 10:09 pm
Torque settings for struts PT GT Turbo Wheels/Suspension/Handling 1 24 Apr 2003 02:35 pm
