Clunk in front
  • 1 Post By cruserdad1976
Old 07 Aug 2013, 10:32 am
Default Clunk in front
Had a clunking sound from the passenger (uk) side of my 2003 limited pt for over 12 mnths now had 3 different control arms fitted, and had tie rod swapped, new sway bar links/ bushes. 2 seperate mechanics can't find the problem, but seems like whenever I work on it, it goes away for a while, then comes back. Also seems less when the car is fully loaded/heavy.
Worrying thing is the steering has started to get unstable, wandering on bumps in the road.
Any suggestions would be gratefully recieved, as this thing is doing my head in, and I love my PT!
Old 07 Aug 2013, 10:36 am
randyincctx's Avatar
Question Re: Clunk in front
Did they check your struts?.....Might be loose,or bad.
Aka:~KILLER~
Old 07 Aug 2013, 11:20 am
cruserdad1976's Avatar
Default Re: Clunk in front
for sure sounds liek a bad strut
randyincctx likes this.
Old 07 Aug 2013, 12:42 pm
Thank's guys, you have confirmed my suspitions. I was going swap the strut and see. It looks ok and doesn't bounce too much, but the more I think about it the more it looks that way. I usually do most repairs myself, but just couldn't see any breaks or leaks, so I will order one asap.
Thank you for the quick replies.
Old 07 Aug 2013, 01:22 pm
Lightbulb Re: Clunk in front
First thing you could do is look at is the bearing plate on top,you may have a loose/missing nut,and the bearing may be bad........If you can have someone push firmly up & down on the front end,you might be able to pinpoint where the 'clunk' is coming from.
Aka:~KILLER~
Tags
clunking
clunk clunk durango Tech & Performance Forum 11 01 Aug 2016 10:26 am
front end clunk at low speed gfp55 Wheels, Tires, Suspension 54 12 Jan 2016 11:42 pm
Loud clunk from front end suspension RainWind Wheels, Tires, Suspension 4 15 Dec 2012 01:48 pm
New LCA's and still have a clunk... Jetta02awp Wheels, Tires, Suspension 0 24 Jul 2010 07:13 pm
Strange clunk frankb Tech & Performance Forum 4 30 Nov 2009 08:10 pm
