car temp goes hi wen AC on?
  • 1 Post By Busted_PT
Old 08 Aug 2013, 01:41 pm
notime0075's Avatar
Default car temp goes hi wen AC on?
driving down I-95 with ac on as ususal and tried to floor it to pass a car , then when I got off 95 it was getting hot fast... I pulled over, pop the hood and everything seemed normal. Started up temp went down but as soon as I turned ac on it would slowly get hot.... WHY?
Old 08 Aug 2013, 02:22 pm
Default Re: car temp goes hi wen AC on?
Sounds like the fan isn't working when the AC is on. You should here the fan running as soon as you turn the AC on.
notime0075 likes this.
Old 08 Aug 2013, 03:23 pm
notime0075's Avatar
Thanks I will go see right now...
Old 08 Aug 2013, 03:33 pm
notime0075's Avatar
Fan came right away then we turned off ac and fan went off but came back on when temp was at half way,.... arent there 2 temp sensors? OHHh and also wen we turn car off the fan sounds loose but thats been going on forever and wen we change power steering pump i checked the fan while it was out and it didnt seem loose.... hmmmm
Old 08 Aug 2013, 04:46 pm
Lets try to get this straight.
On your first post your said you "tried to floor it" to pass a car. What happened, didn't the PT drop into passing gear? What do your mean by "tried' ?
Then you said, "Fan came right away then we turned off ac". Is that what you meant to say OR that the fan came ON right away when you turned ON the A/C?
Which is how it's supposed to work: A/C ON, Fan ON.
Old 08 Aug 2013, 05:01 pm
notime0075's Avatar
okay when we were on I-95 my son was driving and we had ac on and he tried to pass a car and i heard the car rev up hard, i looked at my son and he said he had the pedal to the floor because it would not go, then it got hot, we pulled over, made it home and then you told me to see if fan came on when ac was turned on and it did, so im wondering now if it could be a temp sensor..... also the fan is loose and its been that way for awhile, so im guessing the fan could be not operating properly or a temp sensor is not working. But I know the water pump is good, and there is no clog in the radiator, and thermostat should be good, but we may need to change the radiator cap.
Old 08 Aug 2013, 05:14 pm
Yes, as CREWZIN said seems that your fan is working. Is the overfloe tank at the correct level. You must eliminate the possabilites from here. Assuming that the fan is working at full capacity.
Avg motor temp? Darthmactis Tech & Performance Forum 26 16 Feb 2013 01:41 pm
temp guage loederd Tech & Performance Forum 1 02 Dec 2012 03:37 pm
Keep your eye on your temp guage CREWZIN Tech & Performance Forum 26 13 Aug 2009 10:48 am
temp guage cruiser12 Tech & Performance Forum 0 04 Nov 2004 03:43 pm
oil temp brngrhd General Turbo Discussions 0 17 Mar 2004 12:53 am
