Engine light on question
Old 09 Aug 2013, 07:12 pm
Default Engine light on question
Hi gang
3 years ago I installed the Dodge Neon Stage1 CPU or whatever it is that bumps up the HP on the turbo lite in the car, now it has to go into the shop because the engine light is on. Will the OBD codes work OK after making this change?I also have the aluminum mandrel bent pipes for the turbo, and a K&N filter with airbox baffles removed. Car seems to be running fine
Thanks
Stu
Old 09 Aug 2013, 07:31 pm
Default Re: Engine light on question
Even with adding the stage 1, you should be able to get your own codes when the engine light is on. Try it....
How to retrieve fault codes.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Yet another engine light question. sbartps General Turbo Discussions 1 29 Jun 2009 08:02 pm
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
