PO108 CODE??? GEEZE..
Old 09 Aug 2013, 09:05 pm
Default PO108 CODE??? GEEZE..
ok just put a new timing belt and ,,water pump in and I had a getting hot issue that I THINK I solved?? with a new radaitor cap??,,it was shot..anyway now i"m gettng the po108 code and it stuttering a little at start up?..
any thoughts?....and is the map sensor the crank sensor? and were is the ASD fuse and what is it?..I saw these posted about the code..
Old 10 Aug 2013, 01:51 am
Default Re: PO108 CODE??? GEEZE..
P 0108 = map sensor - high voltage. Check wiring first, and unplug and plug in connector.
Old 10 Aug 2013, 08:04 am
ASD fuse is No#13 in the PDC = fuse box in the engine compartment.
Here's the MAP sensor.
Old 10 Aug 2013, 11:30 pm
thanks man..I replaced the map sensor today the housing was busted some how from the timing belt change?? anyway it seems to have fixed the miss..
Ecc code jondickson Tech & Performance Forum 0 29 May 2013 11:22 am
CODE P0339 NOW, NOT "ALL" FIXED CODE YET HarleyTom Tech & Performance Forum 0 14 Nov 2012 03:23 pm
OBD Code PO108 ( Looking for a repair shop in georgia) cartech468 General PT Cruiser Discussions 6 01 May 2011 08:52 pm
344 code jkinard73 Southeast PT Forum 2 08 Apr 2009 12:54 pm
