Error codes PO633, 551
Old 10 Aug 2013, 07:11 pm
Default Error codes PO633, 551
Thanks for the tricks to get the codes, worked fine. According to my Haynes manual, 551 is "incorrect power steering switch input detected". What does it do? Is it something that needs fixing if I don't want to end up in a ditch? The steering feels fine and fluid level is OK.
633 says"skim key not programmed in pcm". Is this related to the Stage1 module I installed 3 years and 8000 miles ago? I'm 76 and can't do my own work anymore so I'd like to know if I can just stick a piece of tape over the icon or spend a lot of necessary bucks at the local dealer.
Many thanks
Stu
Old 10 Aug 2013, 07:23 pm
Default Re: Error codes PO633, 551
Stu,
First, to get rid of the engine light, take off the negative battery cable for about 5 minutes. While off step on the brake pedal to get rid of residual charge. Then put it all back together. This will reset the computer and clear the codes.
The power steering switch monitors the pressure in your steering system. It does go bad and sometimes start to leak. It could also indicate a problem with the steering pump. Easiest thing to do is replace the switch and see if that is the cause of the fault code. (pic of switch below).
The other code could be a one-off and clearing the codes as described above might be the last you see of it. On the other hand, if you having any problems with the chipped key or fob, opening, locking or starting the car, you could have a skim problem.
Error codes: Luvour04ptgt Turbo Performance 3 25 Aug 2013 09:16 pm
Error codes 301 and 441 kowalski4 Tech & Performance Forum 0 10 May 2012 11:39 pm
Error Codes Error lilcruiser Tech & Performance Forum 2 10 May 2012 05:34 am
error codes??? Turboguy85 Turbo Performance 2 22 Sep 2010 05:15 pm
ERROR CODES Kirby General PT Cruiser Discussions 4 24 Oct 2006 03:15 am
