Fuel Tank Drain Plug
  • 1 Post By Busted_PT
Old 11 Aug 2013, 01:26 pm
Flowrider's Avatar
Default Fuel Tank Drain Plug
On my 01 Cruiser the drain plug at the back of my fuel tank is leaking. It appears loose, and can turn to the left or right without tightening. Do I need a new plug or should I put a gas proof sealant around it?
Old 11 Aug 2013, 03:38 pm
UptownSport's Avatar
Default Re: Fuel Tank Drain Plug
I wasn't aware of a fuel tank drain plug.
I could very well be wrong!!!!
Does it look original?
Old 11 Aug 2013, 03:43 pm
Yea that sounds like something dumb someone added. Theres some weird pt owners out there. Post a picture so we can see it.
Old 11 Aug 2013, 05:35 pm
Flowrider's Avatar
I added a pic to my post above. You might have to click on the word image.
Old 11 Aug 2013, 08:09 pm
randyincctx's Avatar
Question Re: Fuel Tank Drain Plug
On most fuel tanks that I've seen with a 'drain plug',it's normally located on the bottom,to make it easier to drain before dropping the tank for service???....That one is located about half way?
Aka:~KILLER~
Old 11 Aug 2013, 08:23 pm
Flowrider's Avatar
It's weird. Even a new factory tank from Chrysler it's a part of it.
Old 24 Aug 2013, 07:29 pm
Flowrider's Avatar
Attachment 8654
An update. I had a pin sized hole in the drain cap at the back of the gas tank, so I used this adhesive by Permatex to stop the leak. It fully cured in 2 hrs.
No more leaks!
Say No To Stock! Cruisers should be customized!
Old 24 Aug 2013, 07:32 pm
That good keep a eye on it for awhile.
Flowrider likes this.
Old 24 Aug 2013, 08:06 pm
Exclamation Re: Fuel Tank Drain Plug
Maybe you ran over some road debris,like a piece of re-tread;Be glad if all it did was a 'pin-hole'........Those things (and other road hazzards) can do alot more damage sometimes than people would think;I used to see at least 1 customer a month,come in after running over/hitting something on the highway/street.
Aka:~KILLER~
Old 15 Sep 2013, 04:53 am
did you have to remove the plug to seal it mine is also leaking. I have arepair book and it says its a drain plug but I can't find any part numbers on it
How do drain the fuel tank & check to see if the motor mount is bad - 2003 PT Cruiser Drip Tech & Performance Forum 8 02 Sep 2013 02:43 pm
Overflow tank wont drain back into the radiator Epicbeans Tech & Performance Forum 5 02 May 2013 08:31 am
01 oil drain plug for 03 LTD? edb General PT Cruiser Discussions 2 13 Feb 2011 04:00 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
oil drain plug tagreen95354 Tech & Performance Forum 14 05 Feb 2006 09:37 pm
