Air Conditioner Help
Old 14 Aug 2013, 02:12 pm
Default Air Conditioner Help
So my car over heats and smokes only when the air conditioner is turned on. Is there a reason why/how can I fix/stop this problem?
Old 14 Aug 2013, 02:18 pm
Default Re: Air Conditioner Help
I forgot to mention it an 2001
Old 14 Aug 2013, 04:21 pm
Your radiator fan is two speeds. Make sure both speeds are working. Many owners have had the brushes inside the fan motor burn out causing overheating and A/C problems.
Old 14 Aug 2013, 04:27 pm
is it an easy fix? I would love to keep my baby as long as I can.
Old 14 Aug 2013, 04:37 pm
Depends what you call easy and how you are at fixing things. First you need to find out if both speeds are working and the CPU is OK plus both relays. The easiest way is to find someone with a scanner. The scanner can run tests through the computer to turn on and off both speeds of the fan which would prove if the relays are good, the CPU is working and the fan isn't burnt out.
Old 14 Aug 2013, 04:42 pm
I'm sorry what I meant to say was is it a costly fix?
Old 14 Aug 2013, 04:46 pm
you can get a new dorman fan on amazon or rockauto for less than $100. there's a writeup in the how to section on how to replace. not too difficult.
2016 Kia Soul Plus Black
Air conditioner question MOPAR_GIRL Tech & Performance Forum 5 03 Apr 2012 08:38 pm
Air Conditioner Air Conditioner Vaccuum or Flap seal issue??? RMThompson General PT Cruiser Discussions 7 25 Feb 2012 02:40 pm
2001 PT Air Conditioner DonGee General PT Cruiser Discussions 12 13 May 2010 11:02 pm
Charging the Air Conditioner chuck2112 Tech & Performance Forum 11 23 Feb 2010 09:44 pm
Conditioner VS Dressings turbomangt The Detail Shop 0 22 Feb 2004 11:05 am
