Transmission Control Solenoid
  • 1 Post By NitroPT
Old 16 Aug 2013, 09:46 am
Default Transmission Control Solenoid
Hey all. I have an 05 PT Touring that I'll be replacing the Transmission Control Solenoid on this the weekend. My question is regarding installation of the new unit and the new gasket. I've seen conflicting comments about whether or not to use gasket sealant on the new gasket when I install it.
Any help and/or advice on this would really help ease my concerns. I've worked on cars all my life, but I've never replaced this particular part and am a little nervous about it. I don't want to jack things up by doing the wrong thing.
Thanks for your help!!
Old 16 Aug 2013, 11:32 am
Default Re: Transmission Control Solenoid
Factory has no sealant, and if you do choose to use sealant it is not going to harm anything.
I personally choose and recommend Permatex Ultra Blue RTV.
It is oil resistance, hi-temp rated and sensor-safe.
randyincctx likes this.
Old 17 Aug 2013, 05:16 am
ad; Like nitro said, do as the factory does. No sealant. RTV and teflon tape are not recommended for hydraulic systems.
Remove anything that's in the way [air box etc.]. Clean old solenoid and connector and surrounding area BEFORE grabbing a wrench. Like immaculate. Remove connector and solenoid. Put solenoid in a clean container. Remove any remaining gasket from the tranny. Careful, as some passages go into the heart of the trans. Clean bolts, oil lightly, assemble. Torque bolts down in stages to squash gasket evenly.
Invert old solenoid and inspect for foreign material in the mini-screens. Report back.
Old 17 Aug 2013, 07:44 pm
Thanks for the input. Got the new solenoid in. Haven't had a chance to inspect the old one, so i'll get back to y'all on that.
Still having the same issues before replacing the solenoid. Getting VERY frustrated and feel I'm throwing good money after bad.
Here is my issue: from a cold start trans in limp mode with error codes P0700, p1603 and occasionally U0101. However, if I drive it till it warms up and then let it sit for about 20 minutes or so, it shifts fine. WTF
When it first started doing this many months ago I figured it was the speed sensors, so I replaced both. No help. While I was at it, I flushed the system and put in new fluid and filter. No help.
I figured I was down to the control solenoid or the car's PCM. I opted for the control solenoid. Which, as I just stated, hasn't fixed the problem. Error code is U0101. So does this mean the PCM is bad and I have to replace that now???
Really would appreciate so help here. I'm at my wit's end and felling very frustrated.
transmission control solenoid leak/gasket dancudayo Tech & Performance Forum 20 01 Oct 2016 02:32 pm
is the tcm same as transmission Solenoid? HawaiianPt Tech & Performance Forum 8 13 Jun 2016 03:59 pm
Transmission Solenoid Pack markroach Tech & Performance Forum 9 06 May 2012 07:00 pm
transmission solenoid mjptcrusier Welcome New PT Cruiser Members 1 31 Mar 2012 02:58 pm
Transmission Solenoid, Interchangeable? Bentron General PT Cruiser Discussions 3 29 Dec 2011 02:05 pm
