ERROR CODE P0171 CAN'T FIX & CLUELESS!
Like Tree3Likes
  • 1 Post By sanatanadharma
  • 1 Post By heifetz17
Old 16 Aug 2013, 12:53 pm
Default ERROR CODE P0171 CAN'T FIX & CLUELESS!
Hello everyone,
My Cruiser is original 2001 with 220,000 miles. I have taken excellent care of it through the years. I have had a check engine light for at least 3 years that produces the a 0171 lean code ERROR CODE. I have thrown too many parts to this problem. Thinking the problem could be caused by erratic engine temperature I replaced the coolant system and the car runs dead middle guage. Thinking there may have been a vacuum leak in the upper intake manifold I changed that out and cleaned the EGR tube. Still nothing???? Change both oxygen sensors. I did take to a mechanic and they said it was a loose Maf wire and "Fixed it" well the light came back on with the same code. I even changed the sensor. So here is a list of parts and work performed.
Replaced both 02 SENSORS
Replaced upper intake plenum gaskets
change the MAF Sensor
PCV Hose replaced
cleaned and tightened EGR Tube
New wires
New plugs
New ECT Sensor
New thermostat
Checked vacuum hoses for cracks visually and with carb spray
Replaced the Upper intake manifold Plenum.
New Radiator
New radiator Fan
I have run the Tourque app on the car while running. and have the following information:
LTFT: 10.2 -24.2 fluctuates @ 2rpm
02 sensor 1 volts .5-.7
02 sensor 2 volts.8
STFT 3.4
I am completely out of answers here? Can anyone help? I have not tried any fuel testing yet. Any ideas?
Thanks and use the forum!
Old 16 Aug 2013, 01:13 pm
Default Re: ERROR CODE P0171 CAN'T FIX & CLUELESS!
Crack in the exhaust manifold allowing air to suck in and confuse the O2 sensors?
UptownSport likes this.
Old 16 Aug 2013, 05:53 pm
Below are the only reasons this code would come on. Hopefully one or more of them help you:
*FUEL FILTER/PRESSURE REGULATOR (LOW)
*INTERMITTENT FUEL SYSTEM DTC
*RESTRICTED FUEL SUPPLY LINE
*O2 SENSOR SIGNAL CIRCUIT VOLTAGE DROP
*O2 SENSOR GROUND CIRCUIT VOLTAGE DROP
*O2 SENSOR
*TPS VOLTAGE CHANGE NOT SMOOTH
*TPS VOLTAGE GREATER THAN 0.92 VOLTS WITH THROTTLE CLOSED
*FUEL PUMP INLET STRAINER PLUGGED
*FUEL PUMP MODULE
*CHECKING ECT SENSOR
*ENGINE MECHANICAL PROBLEM
*ECT WIRING HARNESS INTERMITTENT
*MAP SENSOR (OUT OF CALIBRATION)
-Chris
Old 16 Aug 2013, 06:20 pm
Welcome back Chris.
Old 16 Aug 2013, 06:31 pm
Rearranging the post from heifetz17, we see fuel system problems that an old dirty fuel tank or failing fuel pump might cause:
*FUEL PUMP MODULE
We see sensor and sensor wiring harnesses as possible problems.
However, sensors are said to have been replaced.
*O2 SENSOR
*MAP SENSOR
So what is left, if the motor is mechanically sound, the throttle position sensor circuit.
Caustic likes this.
Old 16 Aug 2013, 07:05 pm
*FUEL PUMP MODULE
*O2 SENSOR
*MAP SENSOR
One great breakdown and analysis right there!
Own a White 2003 Base. If you have free parts, I like free parts, actually at this point I prefer any advice to help chase down my problem.
One day I WILL make my PT behave!
Old 17 Aug 2013, 09:41 am
Thanks all I think I will try with the fuel system and troubleshoot that will let you all know the results.
Tags
bank one, p171 code, too lean
Error code awesome1 Tech & Performance Forum 3 31 Oct 2012 05:25 pm
Unresolved Error Code P0171 cusunfireguy Tech & Performance Forum 3 06 Jul 2010 10:31 am
Please Help P0171 Code Still cusunfireguy Tech & Performance Forum 11 27 Jun 2010 04:17 pm
Code P0171 leftoverture Tech & Performance Forum 1 12 Jun 2009 06:17 pm
P0171 Error code RIvey Tech & Performance Forum 3 02 May 2007 10:24 am
