2004 PT Cruiser won't start but I have power
Old 16 Aug 2013, 07:38 pm
Default 2004 PT Cruiser won't start but I have power
Was in the McDonalds drive thru today, no indication of any engine issue (no oil light, no check engine light, thermostat was good) and engine just shut off. We got it out of the drive thru (which became a push thru) and a young man tried to jump start it, no luck. We let it cool and still nothing. I have power (dome light, radio, windows) but nothing when I turn the key. Cam shaft sensor and timing belt done in 2010. No error codes via the key trick. Took battery cable off hoping to reset computer, no luck. Battery was put in just 7 months ago. Any suggestions?
Old 16 Aug 2013, 07:46 pm
Default Re: 2004 PT Cruiser won't start but I have power
Does it click or make a noise in the engine when you turn the key?
Own a White 2003 Base. If you have free parts, I like free parts, actually at this point I prefer any advice to help chase down my problem.
One day I WILL make my PT behave!
Old 16 Aug 2013, 08:08 pm
randyincctx's Avatar
Post Re: 2004 PT Cruiser won't start but I have power
Could be a loose,or corroded negative ground(TOP) or Positive Starter Connection(BOTTOM).....Follow the cables from the battery,going to the starter(red/+) & ground(black/-)
Aka:~KILLER~
Old 16 Aug 2013, 08:31 pm
No noise at all when the key is turned. Will check cables to the starter tomorrow. Possibly the auto shut down relay from what I thought from other posts.
Old 16 Aug 2013, 08:38 pm
Question Re: 2004 PT Cruiser won't start but I have power
You don't even hear the fuel pump priming the system?
Aka:~KILLER~
Old 16 Aug 2013, 09:06 pm
Nope....you could hear a pin drop it's so quiet.
Old 16 Aug 2013, 09:19 pm
If you are not hearing anything, it sounds possible that it is ignition related. My first stop would be a quick fuse check in both locations (dash and engine compartments).
Could be wiring as suggested (take a look when you pull the airbox to access the engine fuse box), I would expect a low voltage code from one or more sensors though. But that is just me.
randyincctx likes this.
Old 16 Aug 2013, 09:34 pm
Lightbulb Re: 2004 PT Cruiser won't start but I have power
Then it could be the ignition switch and/or something loose,broken,or disconnected in the starting circuit(maybe in the steering column?)......This is just a LONG shot;Try moving the steering column up & down using the tilt lever,and try to start it in different positions.
Aka:~KILLER~
Old 16 Aug 2013, 09:38 pm
This video gives you an idea of what's involved with the wiring inside the steering column,and starter switch.
Aka:~KILLER~
Old 16 Aug 2013, 10:22 pm
I will check out all of these suggestions and keep all of you updated. Thanks!
2004 PT Cruiser Stalled, won't start Jeramill Tech & Performance Forum 2 19 Jan 2013 03:46 pm
2001 PT Cruiser won't start, no power texasrng Tech & Performance Forum 2 26 Jun 2010 10:12 am
2004 PT CRUISER wont start margarcia1028 Tech & Performance Forum 1 22 Jun 2010 07:43 pm
2004 PT Cruiser Wont Start brian_jill General PT Cruiser Discussions 12 18 Feb 2010 01:20 pm
