Flickering Headlights
Old 17 Aug 2013, 03:24 pm
Default Flickering Headlights
I have a 2003 GT Turbo. A few months ago my headlights and dash lights began to flicker. I checked the ground at the battery and removed the battery tray so I could clean the ground be side the battery. This did not stop the problem. Does anyone know what might be causing this problem?
Old 17 Aug 2013, 03:29 pm
Default Re: Flickering Headlights
Dimming would possibly battery or alternator problems but flickering is most certainly bad grounding or electrical connections. Keep looking.
Flickering lights in 2003 Turbo GT
Flickering lights and fluctuating gauges needles...
Flashing dash lights
03 PT Cruiser lights flickering
Old 17 Aug 2013, 05:49 pm
randyincctx's Avatar
Lightbulb Re: Flickering Headlights
This is an older post,not the exact same problem as yours....But could be related to the MFS(which is in the steering column),and therefore worth re-posting for you.
Originally Posted by jensenpro View Post
i'm a mechanic in ny ,have just dealt with pt radio/horn problem ,it's nothing to do with any parts or wiring harness issues,it's a riveted connection between dash bracket and steering column support if you jump with a wire between brkt and support with key on your radio will light up,jump a 12ga stranded wire between the fwd support stud and rearward support bracket half's(stud towards rear of car is fully insulated from brkt),i,m going to try to attach pix,this will fix solve the mystery
Aka:~KILLER~
Last edited by randyincctx; 17 Aug 2013 at 05:56 pm. Reason: Attachments didn't get posted.
Old 17 Aug 2013, 07:44 pm
Ray_Dockrey's Avatar
I think you are sending him in the wrong direction Randy. The flickering has nothing to do with the MFS and what you posted is a fix for intermittent horn and radio issues.
The flickering is a common issue and usually points to a bad ground somewhere or a battery going bad.
Old 17 Aug 2013, 07:58 pm
Red face Re: Flickering Headlights
I know...I just figured: 'lights flickering'=lights/dimmer controlled by MFS....Longshot,but maybe a 30 second check under the column wouldn't hurt.
Aka:~KILLER~
Flickering Headlights 450HP Tech & Performance Forum 1 22 Oct 2012 07:55 am
H.I.D flickering blown05gt Tech & Performance Forum 0 17 Apr 2011 09:20 pm
Flickering lights dom92 General PT Cruiser Discussions 2 01 Mar 2011 06:58 pm
lites flickering 4SPEED Tech & Performance Forum 0 03 Jul 2008 06:26 pm
Headlights flickering when brakes depressed? TripleJackInGA General PT Cruiser Discussions 3 12 Jul 2003 06:52 pm
