06 ECT sensor location...??
Old 17 Aug 2013, 04:45 pm
Default 06 ECT sensor location...??
Already searched and found the pics for 05 and earlier, and one thread said it's pointing at the motor and not the radiator, but I cannot locate it... would appreciate any more clues.
Did the fan motor test and verified fan is good on both speeds, but in testing the motor side of the harness, there's no signal present to energize the relays, either by running the A/C or after reaching full warm-up. Leads me to believe it's either the brain or the ECT sensor, figured the sensor was a little cheaper to replace for my next move.
Meanwhile I'll keep searching, thanks for any input...
Old 17 Aug 2013, 04:54 pm
Default Re: 06 ECT sensor location...??
Figgered all it would take to find it was to post a question and then keep looking.... it points away from motor, toward passenger fender and it looks extra fun to access and remove...
I'll post an update, but anyone who's done this on a post 05 cruzer, feel free to advise...
Old 17 Aug 2013, 05:00 pm
It on the lower thermostat housing. Either pointing towards the radiator or towards the right tire. Check the temp reading through the diagnostic port and use a laser thermometer to see if the pcm is seeing the right temp.
Old 17 Aug 2013, 05:06 pm
randyincctx's Avatar
Post Re: 06 ECT sensor location...??
This shows 2006-2007 Turbo & Non-Turbo PT Cruiser ECT location: | Repair Guides | Coolant Temperature Sensor | Removal & Installation | AutoZone.com
Aka:~KILLER~
Old 17 Aug 2013, 05:07 pm
thanks, any clue what the threshold temp is for activating the high speed fan...??
Old 17 Aug 2013, 05:12 pm
thanks again, saw the autozone pic during the search but it's really not much help when the instructions say "remove the sensor.... install the sensor"... was wondering if the both halves of the thermostat housing need to be removed, or if there is something else that needs to be outa the way to get a wrench on the sensor without having to remove the lower stat housing...
appreciate the input...
Old 17 Aug 2013, 05:23 pm
Lightbulb Re: 06 ECT sensor location...??
LOL....No,if we all hand little hands & fingers it'd really be easier....Other than getting to it,and doing the R/R;Don't forget to wrap the threads of the new one with some teflon tape.(Also,no torque specs...Just tighten securely,I'd measure the exposed threads of the original & just duplicate it.)
Aka:~KILLER~
Old 17 Aug 2013, 05:36 pm
Wondering if the ECT sensor would even have anything to do with high speed fan operation, as it's supposed to come on whenever the A/C compressor is running...???
I can understand the low speed fan depending on temp, so if neither fan is operating I'm thinking it could be pointing more at the PCM....
Once again, no signal to the energizer wiring going to the relays, with both the A/C on and the engine at operating temp....
Old 08 Sep 2013, 12:51 am
Question Re: 06 ECT sensor location...??
I have a 2006 touring that lost both fans/ AC about two weeks ago, your history sounds quite identical... Good voltage and fuses, had fan and relays replaced by mechanic diagnosis, fans still inop, runs without getting hot on my 15 mile commute so far. Any progress with the ECT?
Old 08 Sep 2013, 01:21 am
Hi welcome to the forum MikeLips!
How are you?
Where have you been?
What drew you to the pt cruiser?
Are you getting the 'thumbs up' from other drivers?
Are you in any local clubs?
Have you made any modifications?
Post some pics of your pt cruiser
Location of the crankshaft position sensor on 2005 pt cruiser jimbo1 General PT Cruiser Discussions 14 05 Jun 2012 06:51 pm
crankshaft position sensor veses knock sensor BeagleDad Tech & Performance Forum 6 13 Feb 2012 06:10 pm
O2 Sensor location for 03 PT non-turbo rayzup Northeast PT Forum 3 06 Sep 2010 04:13 pm
oxygen sensor location hamlaker Tech & Performance Forum 3 13 Aug 2010 05:40 pm
location of crankshaft sensor in 2002 dream crusier lilstarfire64 Tech & Performance Forum 1 23 Jul 2010 10:25 am
