Overheating?! Heeellllp!
Old 19 Aug 2013, 08:00 pm
Unhappy Overheating?! Heeellllp!
Hey all! I have an '06 PT with some big (or so I think) problems! A couple of weeks ago, I was driving a long distance and when I went up a large hill I could smell something burning..but it didn't happen again after that. Yesterday, I went up another large hill and by the time I reached the top the temp light was on, it was steaming/smoking, and boiling noises. Someone came along to help me out and it was pretty much out of coolant. I'm going to fill it with coolant in the morning, but I'm wondering if it could be the fan? I just had a new rad put in 6 months ago, so I'm praying that's not the issue again. Any ideas, or advice on how to find out on my own what the problem might be?! Thanks in advance!
Old 20 Aug 2013, 09:12 pm
Flowrider's Avatar
Default Re: Overheating?! Heeellllp!
Check the thermostat. It could be stuck closed.
Old 20 Aug 2013, 09:54 pm
Most likely you have a leak or the fan is no running. Hopefully you didn't kill it by getting it this hot.
Old 21 Aug 2013, 02:27 am
Kit; When you check the coolant in the morning, check the level at the RADIATOR cap. [also check the cap's rubber seals] If not full, then add 50/50 mix [same color]. Then check the level in the reservoir. Add 50/50 mix to the 'cold line'. Then check the reservoir level every morning for a week or until the level stabilizes.
Old 27 Aug 2013, 10:06 pm
How do I do that??
Old 27 Aug 2013, 10:08 pm
I've been doing this since the problem, but it still overheats from time to time. (Not as severe as the first time). Could it be that the coolant isn't flowing properly? I noticed yesterday when I checked it that the reservoir was filled to the hot line, but there was barely anything under the cap..
Old 27 Aug 2013, 10:11 pm
So far, it's not dead!! I'm trying to get by with it until I can fix it, life as a single Muma waiting for OSAP to come in!
On that note..I've had nothing but problems with this car since I got it four years ago. I paid $10,000 for it and have put at-least $11,000 back into repairs..fun times!
Old 28 Aug 2013, 01:19 am
Kit; the coolant level at the radiator cap must be within 1" of the top. Fill to the top before driving! The reservoir tank [expansion tank] should be about 1/3 full when cold and rise when the engine gets hot. Then goes back to 1/3 full when the engine cools. This is normal.
Check the hose from the rad cap to the reservoir tank. No cracks and tight on both ends. I would replace the radiator cap too.
Bleeding the system might be necessary if the coolant is really low.
good luck
HELP! Car is still overheating. Epicbeans Tech & Performance Forum 5 28 Apr 2013 01:28 am
Overheating Help!! Seedman14 Tech & Performance Forum 20 14 Jul 2012 08:14 pm
Overheating.....need help Flipflopcruising Tech & Performance Forum 13 13 Jul 2012 06:01 pm
Still Overheating? JSRocket Tech & Performance Forum 9 13 Aug 2011 01:33 pm
03 Overheating Cruisjim General PT Cruiser Discussions 16 24 Dec 2009 09:26 pm
