Pt just won't start
Old 19 Aug 2013, 08:52 pm
Default Pt just won't start
I have a 04 2.4 turbo and came home with no problems, couple hrs later went to run off and nothing when I turn the key. Lights interior and exterior go on, dash, alarm, horn all work. not even a click! I dropped a starter in and charged the bat. nothing! checked the fuses behind bat, switched them around in hopes it would click even....nothing. i can't tell on the square black fuses if there good or bad. plus it was a sunday night and nothing open. I'm stumped
Old 19 Aug 2013, 09:10 pm
randyincctx's Avatar
Lightbulb Re: Pt just won't start
Ignition switch actuator pin maybe?...
Aka:~KILLER~
Old 19 Aug 2013, 09:18 pm
Default Re: Pt just won't start
I will try the ignition switch and pin, I also had a DONE reading on the dash when checking for code.
Old 19 Aug 2013, 09:24 pm
Question Re: Pt just won't start
No codes,right?.....
Aka:~KILLER~
Old 19 Aug 2013, 09:33 pm
no code! is there a way to check for the black square fuses for good or bad? a test of some type? or just replace....
Old 19 Aug 2013, 09:38 pm
Your talking about #1(30Amp-Pink)& #3(40Amp-Green) in the PDC(under-hood).......Visibly they could look OK,if you have replacements you can try them;Otherwise the way to check is to check for continuity with a multi-meter.(not everybody has a M/M)
Aka:~KILLER~
Old 19 Aug 2013, 09:58 pm
i was talking about the black square ones in the rectangle box under the hood. i can test all the others or can see them if there gone.
Car will not start when Hot Berthold Tech & Performance Forum 6 30 Jul 2015 08:48 pm
where do I start to fix brvalleygirl30 Tech & Performance Forum 1 10 Feb 2012 06:41 pm
won't start lemonee Welcome New PT Cruiser Members 3 25 Nov 2011 02:31 pm
Will not start Oriphiel Tech & Performance Forum 28 03 Nov 2010 10:19 am
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
