2008 Pt Cruiser with the ignition switch
Old 20 Aug 2013, 09:48 pm
Smile 2008 Pt Cruiser with the ignition switch
Today I was told my ignition switch needs to be replaced. The dealership wants to charge us a grand and we don't have it right now. I was looking into some ignition switches and I see that the job is fairly easy. If I replace the ignition switch will I need a new reprogrammed key?
Old 20 Aug 2013, 10:09 pm
Default Re: 2008 Pt Cruiser with the ignition switch
Can you give more background on what the problem is that you are having? I ask because the ignition switch is actually two pieces. The electronics can be separated from the keyed tumbler. If it is strictly an electronic issue, then you can retain your keys. If they need to install a complete assembly, you'll likely need new keys. Dealers don't generally re-key tumblers, so they take the easy way out. A competent locksmith can do the re-key on the new module so that you can retain your keys. If new electronics are installed, then the SKIM module needs to be reprogrammed to the vehicle. Dealers can do this, but so can a few locksmiths (but not many).
Where are you located?
Old 20 Aug 2013, 10:11 pm
It depend whether you need the barrel for the key or the electrical part behind that. Describe the issues that you have.
Old 20 Aug 2013, 10:55 pm
randyincctx's Avatar
Post Re: 2008 Pt Cruiser with the ignition switch
If it's just the ignition cylinder,you CAN change the tumblers,and use your ORIGINAL key(s).......You WON'T need to get NEW keys,or have your SKIM or PCM reprogrammed.
Aka:~KILLER~
Old 20 Aug 2013, 11:33 pm
If it's the ignition switch,or the actuator pin....You can do that yourself also.HowToRepairGuide.com: How to replace Ignition switch on dodge caravan? (Says for Dodge,but it is virtually identical to PT Cruiser)
Aka:~KILLER~
2008 PT Cruiser says key is in ignition Help! My08PT Sound and Security Forum 10 17 Jul 2019 07:11 am
FS: 2008 OEM 'Combo Switch' (turn signal/headlight switch) Maxxam Classifieds: For Sale/Trade 3 08 Aug 2017 06:23 am
Ignition switch lt4supr Tech & Performance Forum 10 21 May 2016 06:28 pm
2005 PT Cruiser Ignition Switch thecrowx General PT Cruiser Discussions 0 28 Aug 2010 02:54 pm
Possible Ignition Switch? bkarr Tech & Performance Forum 4 20 Jul 2008 06:25 pm
