'00 engine swap - opportunity?
Like Tree2Likes
Old 22 Aug 2013, 10:11 am
Default '00 engine swap - opportunity?
Have an '06 that lost it's timing belt, and appears to have experienced some valve interference. Probably going to find a donor-car, swap over the engine/trans, then part out the donor vehicle and dead engine. Searched the forum, didn't find anything for this specific year. Question is... which years will direct swap with the '06? Just the '06, or any more later or earlier years?
Also, see that the turbo/manual appears to have started in '03. Given a running donor-car with all parts (engine, trans, shafts, cluster, ecu, etc), will everything swap over, specifically are all the mounting points there and compatible (intercooler, etc).
Welcoming any ideas (except swapping to an auto!), yet guess if all else fails, will wait out for an '06 manual donor. Thoughts?
Old 22 Aug 2013, 08:51 pm
UptownSport's Avatar
Default Re: '00 engine swap - opportunity?
You're replacing the engine for a broke timing belt????
Even if valves were bent ( and they're not ) they're only a few bucks each.
Sorry to be so cranky but just willy-nilly throwing good engines around strikes me as silly.
zamfir2 likes this.
Old 23 Aug 2013, 03:21 pm
I'm reading that there's inteference between the valves when the timing belt breaks at speed (valves won't touch pistons, yet valves will touch valves). If the valves are bent, then the top-end has to come of, and I've had 0% luck after having a long-block split. Sure, valves are cheap, yet why split an engine when not necessary.
Figure if they keep the vehicle long-term, getting a 1:1 donor-car makes sense. Swap the engine over, do some mx while it's out (seals, belts, etc), sell off all the extras, keep some of the good stuff, etc.
Question still stands... for an '06, what's the year-range that will do a 1:1 swap?
Old 23 Aug 2013, 04:06 pm
change the belt and leave the head on. no need to split the block and head apart. it's reeeeeeeeeeaaaaaalllllyy rare that the valves hit. i've only read of it happening on here once, maybe.
i know i didnt answer your question. i don't know the answer to it.
Old 23 Aug 2013, 04:13 pm
I'm with the others. What do you mean "appears to have experienced some valve interference? I may be wrong but think you have to have the belt back on and running for a compression check to say weather you need a valve or two.
Old 23 Aug 2013, 04:44 pm
cruserdad1976's Avatar
well with all that said here is you answer
the 01-02 and 03 I belives are in some way diffrent however as far as I knwo from 04-10 they are the same Im sure that fromm 06-10 they are I am with everyone else the amount of work involved is A LOT
Didnt see how many miles but relaly hard to bend valvues in a 2.4
Old 23 Aug 2013, 05:08 pm
If your not a turbo then no you can't just drop one in and make a turbo out if it . I am with the others. Fix yours.
Old 24 Aug 2013, 06:18 am
Work is relative. Last weekend, we parted a minivan. Ok, we're doing the doors this weekend, yet it was whole on Sat, and the shell was towed away on Mon.
I've done a few '85 MR2 SC swaps, so I'm familiar with what's required to swap over entire assemblies. Question still stands... what has to swap over, and what mounting locations are missing in the NA?
While writing this, I figured it would be worth the $32 to put in a timing belt to do a compression check, yet after looking up the steps, maybe replacing the engine would be less work. ; )
Old 24 Aug 2013, 09:48 am
2step's Avatar
In '06 Chrysler began using CAN bus PCMs which means the earlier sensors and computers are very different from the '06 and newer.
CAN bus - Wikipedia, the free encyclopedia
There were various on going changes from year to year but I will hazard a guess that there were not as many since '06 so if you find a newer engine, you should be safe. Worse case, you might have to make a minor change of some dinky part.
all the mounts are the same, the trans is different, the axles are different, engine internals are different, IDK about the wiring/ecu differences.
Can I swap a 2001 w/egr engine for a 2002 engine w/o egr? cas0918 General PT Cruiser Discussions 5 15 Feb 2013 11:58 pm
02 engine swap murphy Tech & Performance Forum 2 11 Dec 2010 12:44 pm
engine swap nimblemotors Tech & Performance Forum 10 01 Aug 2009 02:09 am
02-03 Engine swap brit Tech & Performance Forum 0 13 Apr 2009 12:49 am
Engine Swap macster Turbo Performance 3 24 Feb 2004 12:01 am
