Emergency Help - 0344 has me stranded!
Old 22 Aug 2013, 03:18 pm
Default Emergency Help - 0344 has me stranded!
Hey guys, I really need help. I drive a 2005 pt cruiser. I've put a lot of miles on this, due to my job. Some background: I had my camshaft sensor replaced with an aftermarket part two months ago. This fixed the horrible 0344 code and limp-home mode for two months. Lost my job and started heading west across the U.S. to be with family. In Ohio, the exact same code came up. Had both the camshaft and crank sensor replaced with Chrysler parts. Worked like a charm for two days.
Now I'm in Kansas, and I'm having the same exact problem. I've spent almost all my available cash getting this PT Cruiser fixed, and I've spent two days trying to figure out from this forum what could be wrong. I don't know anyone who lives anywhere nearby, so until I get this fixed, I have no place to stay and no job. Here's what I've done so far:
1. Replaced camshaft
2. Replaced crank shaft
3. Erased codes (removed negative from battery, *and* had auto parts store erase the codes)
4. Taped up *all* wiring (nothing was exposed, but I taped everything and made sure it never touches anything vital)
From reading the forums, it looks like the only possible solutions left are:
1. Get computer reflashed
2. Get timing belt examined
Are there any other solutions that I haven't explored yet? I'm absolutely at my wit's end.
Old 22 Aug 2013, 03:27 pm
Default Re: Emergency Help - 0344 has me stranded!
There is a magnet pickup on the camshaft that can go bad. Will it run at all?. If so pull batterycable . And unplug the ccomputer connectors as well as the sensors. Maybe this will get you going again. If no start . Remove the cam sensor turn the key see if the black magnet turns, if so belt is still on.
Tags
0344, camshaft position sensor, camshaft sensor, pt cruiser 2005
eror codes 0344 0016 0522 graydon1973 Tech & Performance Forum 6 24 Sep 2012 08:35 pm
Possibly stranded in UT any peeps? fabreezai General PT Cruiser Discussions 21 20 Sep 2012 06:44 pm
Camshaft Position Sensor - 0344 djsulli Tech & Performance Forum 1 11 Oct 2011 06:41 am
0340 cleared now 0344? tempest0mouthy Tech & Performance Forum 20 10 Nov 2009 07:04 pm
0344 Code-Sensor Changed and now back Cajunsim Tech & Performance Forum 1 19 Nov 2008 07:17 pm
