Does not pass go
Old 23 Aug 2013, 02:26 pm
Unhappy Does not pass go
Okay, this is the order of events for my PT Cruiser, manual transmission...
I popped a curb and my tired went flat, so I was only about a block away from my place and drove it home, there was somewhat of a plastic burning smell when I did. I replaced the tired with the spare, and when driving it to get a new tire the car stopped. I can put it into any gear, and press the gas, the engine revs but it doesn't accept that it is in gear. any ideas? I can still smell burning plastic.
Old 23 Aug 2013, 02:50 pm
Default Re: Does not pass go
i would assume you broke an axle. if you put the car in gear can you push it?
you'll really need to jack it up and look. crawl under there, spin the wheel by hand, and look at the axle
my guess is that the burning smell is either the rubber axle boot spinning on the shaft and melting, or a displaced plastic shield rubbing on the tire
Hello to you too, welcome to the forum. What year did you say your PT is and how many miles?
Old 23 Aug 2013, 03:12 pm
Yeah the car has no problem moving if on a hill, just the gears aren't responding i suppose.
Old 23 Aug 2013, 03:21 pm
pretty sure it is a 2008 or 07 maybe? About 6300?
Old 23 Aug 2013, 03:33 pm
what i mean is
with the car turned off
the trans in gear
and nobody pushing the clutch
it shouldn't roll.
if it does, you likely broke an axle.
does the shifter feel normal? if it feels disconnected the cable might have popped off. you can see where the cable meets the transmission by removing the air filter box. this is easy to check too
Old 23 Aug 2013, 04:58 pm
what i mean is
the trans in gear
it shouldn't roll.
Okay, put it into first, took off the emergency brake, and lifted my foot off the clutch, it rolls just a tiny bit. Also I noticed the smell of burning seems to come from the drivers side, though earlier when the car had been running, I could have sworn it was the passenger's side
Old 23 Aug 2013, 05:19 pm
does the clutch pedal feel normal?
Old 23 Aug 2013, 05:27 pm
when you try to drive the car, are you saying it just sits in place, and the engine revs freely like it's in neutral?
i must be understanding something wrong, because if it did this the car would have rolled away when you did the other test i asked you to do. you know what i mean?
Old 23 Aug 2013, 06:05 pm
If you are going to ride on a flat tire you need to invest in "run flat" tires
Tags
plastic, pt cruiser, transmission
CANT PASS 4 RPM eliseoortiz Feedback and Support 17 10 Aug 2013 10:20 pm
did not pass inspection tbandab Wheels, Tires, Suspension 0 23 Jun 2010 01:38 am
EZ Pass ? snittykitty General PT Cruiser Discussions 24 10 Feb 2004 08:54 pm
