2007 horn wiring diagram
Old 24 Aug 2013, 01:41 pm
Default 2007 horn wiring diagram
Got A air bag light and the horn don't work. Changed the Clockspring($250.00 at the dealer) and still don't have a horn and the airbag light is still on. I'm looking for a wiring diagram for the horn circuit .Any help would be great.
Old 24 Aug 2013, 02:00 pm
Default Re: 2007 horn wiring diagram
While I do not have a wiring diagram for your specific model PT Cruiser I suggest that you have a certified auto electric technician work on your issue? The system which you will find it to be the newer CAN bus communication system is in no way a user friendly system for un-experienced DIYrs like older model OBDII and you could actually cause some issues in the PCM if you are not careful.
Naturally checking for simple function of relay,fuses or looking for detached wires is not in the same reference.
Old 24 Aug 2013, 02:30 pm
randyincctx's Avatar
Question Re: 2007 horn wiring diagram
Since you mentioned the horn not working,and you've replaced the clock-spring;Have you (or anyone) taken a look at the gounding point for the steering column.(see photos)......May not be the same,because the problem this was posted for was concerning the horn & radio working intermittently on Gen-1 PT(Non-Canbus system)....Since the SRS/Airbag is involved,I would definately take Nitro's advice on that for sure!
Originally Posted by jensenpro View Post
i'm a mechanic in ny ,have just dealt with pt radio/horn problem ,it's nothing to do with any parts or wiring harness issues,it's a riveted connection between dash bracket and steering column support if you jump with a wire between brkt and support with key on your radio will light up,jump a 12ga stranded wire between the fwd support stud and rearward support bracket half's(stud towards rear of car is fully insulated from brkt),i,m going to try to attach pix,this will fix solve the mystery
Attachment 8732
Attachment 8733
Attachment 8734
Aka:~KILLER~
wiring diagram? chrisjcb PT Cruiser Convertible Forum 1 03 Apr 2013 05:30 pm
2004 PDC Wiring Diagram? nickcruiser Tech & Performance Forum 4 26 Jan 2013 11:08 am
2009 a/c wiring diagram cruzerdad Tech & Performance Forum 2 19 Aug 2012 07:58 am
Wiring Diagram clint21anne Tech & Performance Forum 10 24 Jun 2012 11:44 pm
PCM wiring diagram PTcruzer02 Tech & Performance Forum 0 10 Nov 2009 09:35 am
