My car just got slower
Like Tree4Likes
Old 24 Aug 2013, 04:25 pm
Default My car just got slower
My car just randomly decided to get slower. A lot slower. I'm confused. I'm driving home going about 55 cruising in 5th and I wanted to get over so I put it in third and floored it. It must have taken 20-30 seconds to get up to 70. Usually it would only take about 5 seconds. I also noticed when I push the clutch and rev it, it takes longer to rev up. It feels like its restricted. Any ideas?
It has codes 1684, 0442, and 0456. I know the 1684 and 0456 have been there for a long time, the 0442 might be new but an evap leak doesn't affect performance. So basically I have no codes pertaining to my problem.
Any ideas where to start? I speed I can't drive it like this.
Old 24 Aug 2013, 04:29 pm
Default Re: My car just got slower
Do you still have the cat?
Old 24 Aug 2013, 04:33 pm
Yea. I floor the car so much though I can't imagine it could clog. I mean I even redline it sometimes before I park just to keep it clean. I drive home from work in traffic, then traffic goes away so I floor it in 2nd, hit 3rd for a lil bit and then park it.
I did notice the lack of power with the AC on, so I shut it off but it's still a turd. Just got off the phone with my family friend mechanic and his 2 ideas were restricted exhaust or timeing bet jumped a tooth. I'll check the belt first i guess since its easier
Old 24 Aug 2013, 04:35 pm
Four bolts and a look see.
Old 24 Aug 2013, 04:39 pm
Vacuum data ?
Boost data ?
Timing data ?
Check compression possibly followed be a leak down?
Check fuel pressure?
Old 24 Aug 2013, 04:48 pm
Originally Posted by NitroPT View Post
Vacuum data ?
Boost data ?
Timing data ?
I didn't want to go there. With the exception of vac. the rest is not a good thing. No boost,) that's it! He lost his boost. A can of pinto's will fix that.
4 rusty bolts that suck and might break. I'm really wanting to avoid this
Vacuum data ?
Boost data ?
Timing data ?
I'll go see what kind of tools I can rent to check that stuff. I'm going to make sure the belt didn't jump first, since its fairly easy and I have these tools
I had to look up one of the codes.... LOL yup don't laugh! You are having 2 related emission codes may be the issue? If you can check you max boost and also the timing advance I am sure you will see both have been reduced. If you could measure you HCs I would guess a raise in them as well?
Find and cure at least 1 of the 2 clear all the codes properly using a Diagnostic scan tool only. I think I remember you saying you had one? Then see what happens. Your battery code should also clear out of RAM and pending DTC as well?l
Old 24 Aug 2013, 04:52 pm
A simple way to check if the CAT is plugged is checking the engine vacuum at idle and "bliping" the throttle. Also using a handheld thermal measuring device can measure higher then normal operating temperatures at idle speeds.
And the HC and CO levels will have exceeded specification limits.
Old 24 Aug 2013, 05:20 pm
My car is NA so no boost here. I called 4 parts stores, I can only a rent compression tester and a fuel pressure tester. Should I buy a vacuum gauge? I mean that would make testing for a plugged exhaust easy? Before the pt I was always a no cat, open long tubes type a guy.
I'll clear the codes, check the timing belt, go rent the tools, and check back a little later. And yea it feels like I retarded the timing a lot.
why would gt seem slower with exhaust open vs stock dickie72 Tech & Performance Forum 8 07 Apr 2012 02:19 pm
STAGE I SLOWER????!!!!! Ptturbine Stage Turbo Kits 41 23 Sep 2003 12:12 am
